05-10 V6 Turbo Kit
We have the first production 4.0 V6 turbo ready to go and are looking for our first customer for the kit. The kit will be at a discounted cost, all we ask for is lots of pics of the install so we can generate the final instructions, as well as dyno results to post up etc. PM for details if you are interested, this thread will also be serving as the install thread and will be posting up all the install pics and dyno results.
We have results from the prototype kit, but we want to get the final dyno results and numbers from the first production kit before we post final numbers and specs.
Kit includes everything needed for the install with exception of tuning.
Specs:
-Comp X-HF Billet wheel 62mm turbo.
(CT4-6262 T4 3" vband with .68 ar rated to 700hp)
http://www.compturbo.com/products/ct4billet/ct4_6262
-Kit itself is very similiar to the v8 kit, all stainless steel piping, with hi-temp coating on exhaust piping, 3" up/down pipes, coldside piping with 3" core front mount intercooler, 38mm wastgate with 6 and 8psi springs (the 4.0 can support around 15psi safely but new valve springs are reccommended when going above 10psi) Manual boost controller, 50mm bov, all install hardware, clamps, couplers etc, 39lb injectors.
1 year warranty on the entire kit and comp turbo.
Still looking! Smoking deal here for your v6! This kit is going to be a torque monster!
