S197 Mustang Forum - S197Forum.com
Go Back   S197 Mustang Forum - S197Forum.com > Mustang s197 Tech Forums > 2005+ Mustang GT 4.6L Tech
2005+ Mustang GT 4.6L Tech Technical discussion about the 2005+ Ford Mustang GT 4.6L
Reply
Thread Tools Display Modes
Old 06-19-2017, 09:51 AM   #1
eighty6gt
eighty6gt is an unknown quantity at this point
Default Gasket surface prep?
I looked around, not much about this on here. Nothing!
I'm cleaning up my cylinder heads, lots of crap/corrosion at the edges near the valley and on the exhaust side. My cylinder head guy cleaned up the exhaust port area a little bit with ... something or other. Seemed like more corrosion the further back you got on where the header mounts.
Mostly I need to know about the head gasket sealing area, is anyone using surface conditioning pads? This is against practice but maybe there is a silver bullet solution. I've gone over it about 3x with gasket remover, seems fairly smooth but there are a lot of rough areas outside of where the original gasket sat.
eighty6gt is offline   Reply With Quote
Old 06-19-2017, 04:03 PM   #2
drive_55_not
drive_55_not's Avatar
drive_55_not is an unknown quantity at this point
Default
Seafoam and 2000 grit sandpaper will remove the old gasket layer net you a mirror finish.
__________________
2010 Grabber Blue Mustang GT,, TKM Forged 3v,, Roush TVS 15psi, a little NAWZ, L&M Custom Cams, ... Borla LT Header's with modified Bassani O/R X-pipe, Stingers ... FRPP 3.08's , UMI UCA/LCA with BMR relocation brackets, 6R80-Quick/6 swap,, REVMAX 3600 Stall, best time on a G-Force T-56 [email protected], 1/8 [email protected], ... 167.2mph on the Texas Mile ...
drive_55_not is offline   Reply With Quote
Old 06-19-2017, 04:35 PM   #3
o2sys
o2sys is an unknown quantity at this point
Default
When I took my heads of it wasnt that bad. Just lots of carbon build up. Used gasket remover and a plastic scraper till everything was spotless.
__________________
Stroked & Blown
o2sys is offline   Reply With Quote
Old 06-19-2017, 05:44 PM   #4
Brick
Brick is an unknown quantity at this point
Default
This is in the 4.0 section, but I'm speaking with my experience on the 4.6 3V...
I think it was on this board where I read about this topic when I had to have one of my heads resurfaced. The advice was not to use any scotchbrite, steel wool, or any kind of do-it-yourself method of prepping a head surface for these newer motors. The level of smoothness required to seal the MLS head gaskets that the 4.6 uses can only be achieved from a machine shop with the proper kind of CNC mill. Seems to me like I remember it needed to be a RA (Roughness Average) of 10 or less.
Hopefully someone with more experience building these motors can confirm this... BruceH?
Brick is offline   Reply With Quote
Old 06-19-2017, 05:56 PM   #5
skwerl's Avatar
skwerl is an unknown quantity at this point
Default
If it is outside the gasket area then I wouldn't be concerned about it, as long as it is flat and not going to interfere with the gasket sealing. Getting too worked up about it may end up with you screwing up the gasket sealing area.
__________________
Quote:
Originally Posted by Fullboogie View Post
I don't like the new Skwerl. I like the dick Skwerl.
Quote:
Originally Posted by o2sys View Post
I go through this cycle every month
skwerl is offline   Reply With Quote
Old 06-19-2017, 10:35 PM   #6
RocketcarX
95% of my weight is fuel
RocketcarX's Avatar
RocketcarX is an unknown quantity at this point
Default
Have them hot tanked at the machine shop or pressure wash them. You can't hurt the heads washing them. Make sure to blow them out thoroughly with compressed air before installation.
__________________
Stealth Fighter Status
"We go together like cocaine and waffles" - Cal Naughton Jr.
RocketcarX is offline   Reply With Quote
Old 06-20-2017, 01:35 PM   #7
BruceH's Avatar
BruceH is on a distinguished road
Default
Solvent clean and scrape with plastic scraper. It takes time but works. Anything else will change the ra.
BTW have you checked the head for straightness?
__________________
Former 2008 GT/CS owner.
BruceH is offline   Reply With Quote
Old 06-21-2017, 10:06 AM   #8
eighty6gt
Default
Straightness, that's a great question... I have been trying - I am probably going to have to get a machinist rule from summit or jegs since I can't find one here. Have you ever had a head that had a bend or twist? I just cleaned out my coolant reservoir and it seemed to have oil in it. I wasn't sure until I actually got it full of soap and was cleaning out the bottom. You'd think oil would remain on the surface, but...
I have cleaned and pressure washed the crap out of these heads, they were unbelievably filthy. I have not used any abrasives on the sealing surface, only gasket remover and plastic scraper blades.
Old 06-21-2017, 04:00 PM   #9
01yellerCobra
01yellerCobra's Avatar
01yellerCobra is on a distinguished road
Default
Quote:
That would also be called warping. And it's been known to happen. I managed to warp two 4V heads when my engine overheated.
__________________
His- 2004 Mystichrome Coupe
Hers- 2006 GT. Triple black drop top.
01yellerCobra is offline   Reply With Quote
Old 06-21-2017, 04:22 PM   #10
BruceH's Avatar
Default
IIRC the modular heads need no more than .001" per 4".
If the motor was assembled with tty hardware it's probably ok. I'd still get the machinists straight edge and check. The mls head gaskets are sensitive to having the correct ra and straightness.
This brings up another topic. If the heads or block need to be machined make sure the machine shop can finish with the correct roughness average for a mls head gasket motor. Believe it or not there are still machine shops out there who will machine your motor like it was a sbc from a 1976 Monte Carlo. The usual selling point is something like "we put together race motors so your little modular motor won't be a problem" Times and machining requirements have changed greatly since machining the sbc or bbc was figured out.
But I digress. Good luck with the build.
__________________
Old 06-22-2017, 02:16 PM   #11
eighty6gt
Default
A thou in 4 is actually pretty curvy. I'm going to get my machinist to make me a piece of steel on the mill that is a lot better than that, compare.
Old 06-22-2017, 02:46 PM   #12
BruceH's Avatar
Default
??? That's the Ford spec as I remember it. No more than .001" deviation over a 4" length.
The straight edge shouldn't have any measurable difference throughout it's length, the .001" per 4" is the head surface.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Ad Management plugin by RedTyger
