S197 Mustang Forum - S197Forum.com
Go Back   S197 Mustang Forum - S197Forum.com > Vendor Forums > Department Of Boost
Department Of Boost
Reply
Thread Tools Display Modes
Old 07-23-2017, 09:56 AM   #1
HDSE
HDSE is an unknown quantity at this point
Default Tiger Racing Hood & Dept of Boost Manifold
I am hoping someone on this forum can answer my question by experience. I have a 06 Mustang with standard motor mount height. I have installed a BMR K member on solid motor mounts. The engine now sits as low at it can be. I am running a Tiger Racing hood and need to If anyone has installed the Dept of Boost manifold with this setup. I need to make sure the Eaton blower will fit under the hood.
Thanks for your time.
HDSE is offline   Reply With Quote
Old 07-23-2017, 10:12 AM   #2
Department Of Boost
Alpha Geek
Department Of Boost's Avatar
Department Of Boost is an unknown quantity at this point
Default
Man, IDK. We ran a Tiger hood on our 2010 but the motor was dropped. If I had to wager I would say yes it will clear. It clears the stock hood and the Tiger is quite a bit taller.
__________________
http://www.s197forum.com/forum/image.php?type=sigpic&userid=6258&dateline=1461790  849
www.departmentofboost.com
Department Of Boost is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Ad Management plugin by RedTyger
