6R80 in my 05
05stroker
Never enough power guy!
Bullard Tx.
hey it's only $$$ right Billy.... :highfive:
I just think the 6r80 would make the car a little more fun on the street. My strip terminator has fixed line pressure and non lockup. That is two things I would change if I was to do a 4r70w again. Thing is though that big ass one PC shaft in the non lockup can hold a lot more power.
tjm73
of Omicron Persei 8
Rush, NY
Not to hijack the thread but Billy, I think it would be cheaper for you in the long run to put a 9 inch rear in the car. It would give you the added benefit of a stronger rear and you could run 2 complete center sections. One with gearing for the strip and one for the Mile. It isn't a big deal to swap out center sections on a 9 inch.
I think this would be a much better way to go than trying to make the 6R work, with your power levels and cheaper also.
Earl
Look into a quick change. Swap a couple idler gears and you just swapped your ratio. Google Winters. There are others.
kdanner
Austin
This is a great option, so many more gear ratios available too. If a 12 bolt GM has the ratio you need, Strange makes a 9 inch center section that takes the 12 bolt parts, this does away with the extra parasitic loss of the 9" gearset.
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
There was a thread about this in Chit Chat about a month back or so started by 05stroker (I think). Sounds like no-one has stepped up with a stand alone controller as of yet. It will be a popular swap once someone gets a controller up and running.
awesome autocorrect malfunctions brought to you by tapatalk
05stroker
Bullard Tx.
Nothing yet that I know of.
Bmr4life
2005 GT
Atlanta
It definitely will be. Mine plan is to buy a dead 1st gen S197, swap in a built FI 4.6L 3V with a 6r80.
retfr8flyr
The Old One
Providence Forge, VA
If I were going to do that I would find an 11-12 that was totaled but had all the wiring in good shape and I would put a 5.0, 6R80 and all the 11-12 wiring harnesses and computer into the S197.
Earl
TexasBlownV8
Formerly TexasBlownV6
Central Texas
It's great to hear that Baumann is working on a controller for a 6R80! I've been thinking about such a swap as well.
I run the same setup, a 4r70 with auto vb, lo tb, lockup converter, using Baumann's Optishift for full automatic control. With 373's, 3rd gear hits 130-ish at 6k rpms.
05stroker
Bullard Tx.
Have you ever spun it higher then 6k? Wondering what it would be at 7200 rpms?
RED09GT
Another way this could be pulled off may be to use a wiring harness and pcm from an 06-10 explorer or sport trac as they had the 3V and 6R80 combo from the factory. It would be pretty labor intensive and would probably take someone like Lito to pull it off.
It's way beyond my capabilities but it could possibly work.
05stroker
Bullard Tx.
Did they use the same PCM (Spanish Oak) as our cars?
RED09GT
I did a quick search and I am not sure. Lito would probably be the guy to ask as he deals with lots of explorers.
crownaviation
http://www.tudyno.com/
Broke dafuk down
Hey crown does nt jd coon run the 4l80
Who?.. lol. My brain is shot. Drove 6hrs this morning to pick up abmr k member, installed that, pulled my trans and worked on two other cars today
4l supposed to be good trans but never ran one. It is hard to look at the 4r sitting on my garage floor again and not go for the 6r. Maybe this winter...
stang67
ohio
Jd coon is his screen name and actual name. He runs a. Gt500 I read in muscle mustangs his car had a 4l80
lito
Caracas, Venezuela
Yes, they have a TCM, latest model (09+ IIRC) use a 6R80, don't quote me on that as I am not completely sure when they did this, they used an 6R60 before.
ummduh
Napa, CA
I don't understand why the no OD comments on the 6R. I've used all 6 gears on the mile before.
In the trucks, Ford even says you can tow in OD with the 6R also. That used to be a MAJOR no-no. The 6R is just a bad ass trans, finally.
