^^Now that explains a LOT!!!
Billy are you back yet? We're at a dead end, need your help..
A couple of questions, my car was also originally a BKT3 car and Im running the same manual strategy as you are now.
Do you have pin 39 on 175b at the PCM grounded?
Do you have B9 and E10 at C1035B tied together if you car was originally a auto car?
For my reverse lights I used C2280 and tied together pins 26 and 13, then connected the wire from my Quick 6 to both of them.
Also that C175B pin 33 YE/LG is to the power steering pressure switch on our early model cars. I have an 06' wiring diagram manual here. Even some of the wires are different colors on my 05' car.
The pin is in the PCM just no female in the harness. I used one from and old harness I have here. If you need a female pin, I can send you one.There he is!! No I don't have #39 grounded on c175b, I'm pretty sure that pin is currently empty, no socket / no wires attached or coming out of the plug at all.
I have B9 and E10 ran through my neutral safety switch on the shifter now, so as long as the shifter is in park or neutral they are essentially tied together.
I'm not too concerned about my reverse lights right now, maybe after I get these DTC's cleared.. thanks a million for your help. How did you ground pin #39 in c175b if there was no socket?
Thanks Lito and Billy for clearing this up, so the prints online are mis-marked as 2005 when they are 2007 and up. Not much was making sense trying to wire this up, it would sure be helpful if anyone could post these prints up and add to a sticky as this ones important.
Thanks again Billy and Lito.
Wow! So that is what is gong on. I misread earlier what was being said. Thanks for clarifying. Wish now I had not sold my 2005 shop manual set (paper version).
Well I feel relief, and when I get home I'm going to make my wife read this thread so I can prove I'm not senile and in need of a good retirement home that she keeps suggesting.
Kurt well said! I would have my wife read this thread, but I think it is to late for me as I am pretty sure she is already packing my things for the retirement home! Hope you get your issue resolved in short order.
I'm using an X4 now and have the following codes.
P0481
P0581
P0689
P0830
P0340
P0344
