Thought maybe I could get others thinking. This really isn't a difficult thing, so background on how the trans and transbrakes in general function. Someone might want to attempt this themselves.
Any transbrake you buy is going to raise line pressure in order to increase the amount of torque the elements can hold. By elements I mean clutches and bands. There are no bands in this trans, so only clutches. Some want to say raising the line pressure is bad, well they can think that if they want, I disagree.
Also any transbrake is going to have a limit to the amount of input torque it can hold. I mean think about it, don't tell me I can bolt up a blown nitro hemi to your brake and it is still going to hold, there is always a limit. This can be increased by line pressure as mentioned above, or by increasing the amount of clutch plates in the elements which are holding when on the brake. I said increased, because while you can raise the limit, there is still always going to be a limit, the point is to have the limit out there high enough to make the brake a usable tool with a given combination.
If you've never used one, don't think it is like dumping the clutch in a manual car. There are some similarities, the suspension stays relaxed, the driveline isn't loaded behind the trans, but the "hit" is not as hard as a manual trans.
Next lets look at the elements in this trans and how they might be used as a brake.
