13" brakes?
Goody05
Omaha NE
Does anyone know of a kit that would allow me to put a 13 inch rotor on my stock GT caliper? I know that baer makes the 14 inch one but I don't think my wheels will allow it. I would like to upgrade my rotors since I need to do a brake job anyways.
Thanks for your help
demarcom
South Charlotte, NC
You can go with a Stoptech rotor that is slotted but stock size. I don't think 13" is much bigger than stock. You may also find slotted/drilled if that's the look you are going for
luillo
Fort Walton Beach, Florida
I am not sure what you mean but 2011+ mustang use different caliper brackets to accommodate a 13" rotor in the front if I am not wrong.
Goody05
Omaha NE
There is plenty of good replacement rotors but I was looking to go a little bit bigger just to help with leverage. I don't want to pay $600 on rotors and bracket from Baer and mount them just to have to resell it because my wheels won't fit. If I could find somebody that has the 14 inch upgrade and get them to measure from the furthest wheel stud to the furthest point on the caliper I could maybe see if the measurements will allow my wheels to go on or at least a little bit of hope lol.
Goody05
Omaha NE
Yes I know that but who makes a caliper and a bracket? I know Baer makes one but it is for a 14 inch set up.
07TGGT
@user
Mansfield, TX
I don't believe anyone makes a 13" kit for ours.
So the only choice is upgrading to 2011+ GT bracket and rotor. I am pretty sure you use your current caliper as they are the same. 13" just like you want. A search would have showed you that.
Goody05
Omaha NE
I think everything I search for is grouped together from 2005 to 2014 all be in the same brake. And I think it's a 12.8
07TGGT
@user
Mansfield, TX
2009-2010 GT rotors are not the size of 2011-2014 which are 13". If you don't want to believe me then good luck trying to find something.
stang8psi
Slower,Lower Delaware
2011+gt are 13.2" find someone who wants to switch to accommodate a 15" front wheel. Or call tasca they will have what you need.. and all you need is the caliper bracket and rotor. The calipers are the same.
luillo
Like I said, my stock brakes where too big for the 15" race star and I swap brackets and rotors from a 2010 gt. I know 2005-2010 gt rotors are smaller than the 2011-2014 gt for sure I just don't know how smaller. I think 2005-2010 gt are 12.5 vs 13" 2011-2014. Same caliper anyways.
Goody05
Omaha NE
Yeah I just don't get why they all group them together like I see on their websites. And I do appreciate your guises help
thank you
Conekiller
Baton Rouge, LA
http://www.stage3motorsports.com/21...GT500-DBA-Rear-Drilled-Slotted-Rotor-Set.html
http://www.americanmuscle.com/2005-2006-mustang-gt-v6-powerslot-rotors-rear.html
This is just two of them, if it's different size I wish they would say so. I'm not arguing with you so you don't need to get so defensive.
The reason it shows from 2005-2014 is in 2011 they upgraded the v6 to use the same size brakes as the previous year GTs, hence the (GT/V6) application listing. The GT got an increase from 11.8" front rotors (per the size listed in your first link) to a larger 13.2" rotor while maintaining the same caliper with a new bracket.
TGR96
el blanco nino
Huntsville, AL
This. If I were in your shoes, I'd just upgrade to the stock rotors/brackets from a 2011-2014 GT. You'll notice a difference.
If you are interested, I have a set of rotors/brackets that I took off my '13 GT with only a few thousand miles on them. I'll cut you a good deal on them, I just need them out of my garage. However, shipping will probably not be cheap. Brake rotors are pretty heavy. PM me if you want them.
Whiskey11
SCCA Autoscrosser #23 STU
The 05-09 GT front rotors are 12.4" in diameter. The V6's were smaller.
Goody05
Omaha NE
Which bracket? The 2011+ GT caliper bracket?
A dealership, or a Vendor who sells OEM parts on here such as Steve@Tasca Ford. It's not that hard to figure out.
It's unbelievable how helpful you are, sorry I don't know who Steve is and you know as well as I do dealerships try to screw you over as much as possible on price for parts. I have searched a lot of places on other websites and I don't see any other bracket. So excuse me for asking.
