Tired of over paying at shops for labor & parts?! We got a killer deal for you! For a limited time only, we're installing FRPP gears & install kit starting at $555.99! That's cheaper then most places will charge you for LABOR!
4.10 1986-2009- Price: $559.99 (Includes everything you need as well as LABOR!)
4.10 2010-2014- Price: $579.99 (Includes everything you need as well as LABOR!)
3.73 1986-2009- Price: $555.99 (Includes everything you need as well as LABOR!)
3.73 2010-2014- Price: $579.99 (Includes everything you need as well as LABOR!)
(1) Ring gear
(1) Pinion gear
(1) 3.8 fluid oz bottle of Friction Modifier
(2) one quart bottle of Royal Purple Max Gear 75w90 Gear Oil
Front & Rear Pinion Bearing
Pinion Seal
Carrier Bearings
Carrier Shims
Differential Bearings
Crush Sleeve
Pinion Nut
Cover Gasket
Ring Gear Bolts
Brush
Gear Marking Compound
Loctite
We can do almost any gear ratio, please contact us if you don't see the ratio your looking for.
(1) Ring gear
(1) Pinion gear
Pinion Seal
Carrier Bearings
Carrier Shims
Crush Sleeve
Pinion Nut
Cover Gasket
Ring Gear Bolts
Brush
Loctite
