DIY Fluid Dispenser
Scott
King City, Ontario, Canada
Worked great for me in January 2013 on my forged motor.
The pre-lube configuration consists of the following parts:
- Napa ¼” inlet and outlet Gold Fuel Filter, part number 3001
- WATTS 3/8” Barb x 3/8” MIP Hose Adapter, part number A-294 (Pressure Tank Hose to Shut Off Valve)
- WATTS ¼” Barb x ¼” MIP, part number A-192 (Pre-luble tube to Oil Block Adapter)
- WATTS ¼” Barb x 3/8” MIP, part number A193 (Shut Off Valve to Pre-lube Hose)
- WATTS ¼” I.D. x 3/8” O.D. x 10’, Clear Vinyl Tubing, part number SVGE10
- Aqua Dynamic 3/8” Ball Valve, part number 1107-002 (Oil Flow On / Off Valve)
- RL Flo-Master Sprayer 2 Gallon Translucent White Polyethylene Tank (Clearly would have preferred a 1 Gallon Tank, but try finding one in January)
- Loctite 567 Thread Sealant
Assembled.
Pre-Lube attached to the Oil Adapter, Oil Pressure Sender Port
As an example, break-In Oil flowing to the Lash Adjusters.
