Hissing/white noise after suspension lowered
TOWGUNNER
Texas
Gentlemen
Need your help please. I’m having trouble trying to diagnose a noise coming from the rear passenger area of my 2007 GT500 with only 5k miles. The noise that I am hearing is a constant hissing/white noise. It only does it when the car is in motion. It does not go away when applying the brakes or pressing in the clutch. I checked to see if the Ebrake lines were rubbing and that’s a negative. It doesn’t get louder with speed just a consistent noise. I thought it was the caliper rubbing on the brakes/rotors but seems not to be the case? All I had installed were some racecraft lower control arms, Eibach sportline lowering springs, and a racecraft adjustable pan hard bar. All mentioned parts have been on the car less than 100 miles. Is this normal to hear that? I know when messing with the suspension you are going to get a lot of road noise but wasn’t expecting this. If this is normal then I will be fine with it, if it’s not ill be taking It into the dealership to get it looked at since I have warranty on it. I had my son record the noise but having trouble trying to load the video on youtube to post on here. Thanks for your time.
are the LCAs poly or rod end?
it sounds like just added NVH from the suppension upgrades
Those links just bring me to the home page. If they are spherical rod ends, they pass a lot more noise from the chasis. The stock parts hide the noise.
TOWGUNNER
Texas
sorry here are the pics attached. Thanks for the help.
those are rod ends... you'll be hearing a lot more noise as a result. 99% probability that what you're hearing is totally normal.
TOWGUNNER
Texas
Ok thanks gents I'm definitely liking that they keep me going forward and no wheel hop
black2008gt
GT500 NOOB
San Antonio
Its NVH from the supspesion components. Same noise happened when i upgraded to spherical bushings.
46Tbird
DFW USA
It only does it when the car is in motion. It does not go away when applying the brakes or pressing in the clutch. It doesn’t get louder with speed just a consistent noise.
Check your rear brake dust shields. They are thin sheet metal and bend easily. You might have done something that pushed one of them up against the rotor.
TOWGUNNER
Texas
Yup that was the first thing we checked. That's a negative on that. Thanks.
thetylerjames15
Similar problem
I have the same type of noise however it only happens when I press in the clutch.. I also have a lowering kit
