JPC not available.
Just a month or so ago they had one left in stock. They will make a run of them if you have a group that is interested.
JPC not available.
From what I understand the 92mm and 102 is available... is the frpp tb a 92 i cant even remember lol... Is the 102mm another ls cable drive deal??
http://www.jegs.com/i/Holley/510/829081/10002/-1
i thought the only ford motor worth modifying was the coyote
I looked on the side and they have a cable drive tb listed as needed as well as a gasket listed as for 2v's since it isn't o ringed.
On another forum I did see a pic of this with the standard twin throttle body, so I'm assuming like others said this is just a generic pic used as a placeholder
Sent from my HTC One_M8 using Tapatalk
Any info on runner length vs stock and Ford racing intake manifold, I have the Ford racing one now mostly for looks it would be nice to find one that performs and doesn't loose as much torque as I do with the fr one
Here's a better pic that Evan smith from MMFF took while at PRI.
Coyote on the left, 3V on the right.
After running the FRPP for years NA/N2O I'll never run another short runner intake manifold again. Trading torque for hp IMO is bad for just about any autosport. I can see a turbo car benefit from an intake like this, only in an extended rpm range for a proper sized turbo. A huge nitrous shot in a direct port set up may yield some gains vs stock, although direct port on a stock manifold makes its own brand of evil, and you don't have to worry about spraying in the redline.
JPC was on the right track with their long runner intake, IMO.
I'm having similar thoughts. What is the advantage to a short runner intake? I read some info on the C&L website about a short runner version of their old long runner intake that isn't made anymore. Not sure if it was just pr from a project that never made it or if they are indeed coming out with a new intake. They were also talking about 3v heads made from their own castings. Probably another project that got shelved when the 5.0 came out.
Does anyone know what the volume in liters is for this intake?
Not sure if you have seen this yet or not. The curves with more power were done on e85 and with the frpp manifold. The curves that peter out around 6k are from the stock manifold with cmcv and 92 octane gas.
It's quite evident that the stock intake flows better at lower rpms. It does have it's limits in a n/a application though.
I'll go back on the dyno with the stock intake and e85 sometime in the next few weeks for a more apples to apples comparison of the stock intake with gas and e85.
The stock intake made a little more power that the frpp in the lower rpms even with gas as a fuel. At first I was bummed about the peak power being off but the more I think about it I don't usually go over 5k on the street anyway so having more power with less revs fits me pretty well.
interesting, I wonder if there would be any benefit running this manifold over the FRPP manifold I am running now.
