How screwed might I be?
themoose06
Woodstock, MD
So I noticed a small leak on my garage floor, smelt it and determined it to be coolant. Upon further investigation, I found my coolant to be a little low... okay it was alarmingly low.
Haven't gotten to look more in the reserve tank to see what the milkyness is, but i'm not looking forward to finding the answer. I flushed/changed my coolant at 107k (15k ago) can't seem to see the leak yet. What could this be? While I dont want it to be a major engine issue, I wouldnt mind having a reason to be swapping the ol v6 out for a nice v8 upgrade.
Wes06
check the res, if its not milky could be the plastic thermostat housing cracked?
themoose06
Woodstock, MD
I'll inspect it more, but it was changed 15k miles ago as well
07gts197
Naples, Fl
I second Wes. Its really common for the thermostat housing to crack on the 4.0 because its plastic.
JimC
Even if you replaced it 15,000 miles ago, the thermostat housing could have split already. Just a crap shoot how long one lasts. On my 2006 the original lasted 190,000 miles. But a friend had to replace his at 45,000 miles, then again at 60,000 miles.
Anytime you lose coolant with the 4.0 the first place to check is the thermostat housing.
RocketcarX
95% of my weight is fuel
Colorado
That looks like a combination of rust and mixing incompatible coolants to me.
themoose06
Woodstock, MD
There was never any mixing of coolants. Only used one brand. Flushed it fairly well too. Don't think its rust, seems more like oil to me and everyone else
oldVOR
Northern Virginia
Along with the compression test, do a leak down test. The combination of both will be very insightful as to any issues.
oldVOR
Northern Virginia
Another thing comes to mind, did you use well water for the coolant flush?
If so, you could have introduced solids into the coolant system which can produce the sludge you're seeing.
themoose06
Woodstock, MD
I used water from my hose in a bucket and flushed it like that. Not on well water though
RocketcarX
Colorado
A real easy way to check for a blown head gasket would be to have a block test done, its fool proof and straight to the point.
themoose06
Woodstock, MD
I think i'll do a complete flush of the coolant first. Last time I "flushed" it I only really cleared out some of the front piping and up to the thermostat housing. Cousin thinks it was sludge that wasnt flushed out that made its way up. So once I do a legimate flush, if the sludge comes back, then I have to look deeper. Not as sure on it being a head gasket. Especially with as little sludge thats come through, and how theres no pressure or smoke/steam outta the oil fill. Also no coolant in the oil.
RocketcarX
Colorado
There doesn't have to be coolant in the oil for a head gasket to be blown. It's a cheap test to rule out the worst if you really do suspect oil in the coolant.
Sludge doesn't develop in cars for no reason. You would have to run the coolant low for an extended time, have oil getting in, or mix incompatible coolants. Considering you recently flushed I think it's more reason to do the block test. If it's an auto there is the chance the ATF oil cooler is leaking into the radiator.
themoose06
Woodstock, MD
Id be surprised if it was a head gasket. Only 122k miles. Its an auto, so theres definitely a possibility of it coming through the radiator. How much does the test cost?
