Squeaking/chirping noise.... Throw-out bearing like...
white95
boost or bust
Prairieville, Louisiana
Let's play a game!!! Guess that squeaking/chirping noise!
I'll take another video that shows the noise better.
Given the fact these cars have hydraulic clutches, do they eventually eat throw out bearings like the old 79-04 cars? It doesn't squeak/chirp at idle but does with throttle input. Seems to be coming from under the car and is present with clutch in or out.
Can't really hear much in the video. If its the slave cylinder it should do it all the time. Even just sitting with the car off pushing the clutch, that's what mine did anyway. Essentially the rule of thumb for these cars is to replace it any time you change the clutch and to fully bench bleed it (fill it with fluid and get all the air out prior to install).
