changing pistons.. Balance the engine or not?
walmore
LUBRY SPORT
venezuela
Hi there
I´m changing the pistons of the my engine 4.6 3V, the weigth of the stock pistons are 460gms and the weight of the new pistons are 466gms. The question is if I have to balance the engine?
thanks for your help
drive_55_not
I know the LS guys will simply throw new rods/pistons into their junkyard motors and run em', but they also don't turn the 7000+rpms the Mod motor can ..
IMVHO since it's apart, have it balanced.
RocketcarX
95% of my weight is fuel
Colorado
You'll be fine as is, 6 grams is essentially the weight of a nickel
tjm73
of Omicron Persei 8
Rush, NY
You'll be fine as is, 6 grams is essentially the weight of a nickle
In total 8 nickles then.
If it's coming apart to have new pistons installed, balance it. It makes a difference. The piston pins also factor in to it. Did you account for the weight impact they will have? What about the ring pack? If you are spending several hundred dollars to do this swap, why not spend a little more to have it balanced correctly?
RocketcarX
Colorado
The guy I learned to build engines from would say let it go, we saw this a lot messing with race engines, just my take on it though.
Ask the machine shop you use ands what they say.
You should weight the piston, pin and rings and then compare, its possible after that the weight difference is even less.
BruceH
BBB Big Bore Boss 322
Have it balanced. You have no way of knowing what the original balance specs were and/or how well it was done.
RocketcarX
Colorado
This is true, I hadn't factored in the original balancing job being an unknown factor.
tjm73
of Omicron Persei 8
Rush, NY
A friend of mine that has built a bunch of performance engines for other people I know says if you change something, balence it.
eighty6gt
You would be fine but with all of the bad karma from posting this in tech you should probably balance the engine to be safe.
wabirch
Bill
Illinois
If you can add it to the budget knowing things could be pretty tense at home, it makes sense to add this to the list.
