Bill220
- Joined
- Oct 13, 2011
- Posts
- 858
- Reaction score
- 0
This is a shot of my Paxton 2200 intercooled oil pan feed unit pretty sure there was no line which could mean yours is correct since we have opposite units.
What's the part # on your head unit ? (Looks like 1016154 when I blew up your photo) you can then look in The manual and should tell which on you have
You buy the self lubricating standard ? If so part # is 1016154
http://www.paxtonauto.com/pdf/manuals/4809654v4.1.pdf
Exactly
Expect shit to not work 100% when modifying your car. I wanted to set mine on fire probably a dozen times during my engine build/swap
That's what it is! Gotta find a way to hide it. Thanks!
We can't get the belt on. Any ideas? Been pressing down on the tensioner and it's still too tight. Ideas?
First I'd double check the routing. Not sure what belt length and pulley size is included with your kit but it should go on with the tensioner down.
Did they have you cut the stop off of the tensioner? It's common practice with forced induction and might help with travel needed to install the belt. It's been awhile since I've had a Paxton on.
