Jason
Here’s the story…I did a wire tuck a couple of years ago, everything has been working great, until now. I’ve been experiencing a fuel pressure issue. I thought at first it was the pump, so I switched it out, still nothing. Went on to the FPDM, switched that out, nothing. I then moved on to the BEC that is now located in my glove box —pictures below— to check if any wires were loose or damaged. I unclipped the two plastic fasteners from the BEC housing, inspected the wires, everything looked fine. Put the BEC back in the plastic housing, boom, fuel pressure. Maybe a wire was too snug? Everything worked great again for a couple weeks, then it happened again.
Basically, it’s to the point of when I unfasten the BEC from the housing and let it hang down by the wires, I get fuel pressure. When I put it back in the housing, fuel pressure goes away. However, if I start the car with the BEC hanging down and let the car run while mounting the BEC back in the housing, car still runs. The minute I turn the car off and back on with the BEC back in place, car immediately dies because it lost fuel pressure again.
I’m getting power to the white power wire to the FPDM. I have a limited knowledge on the relationship between the FPDM and how it works with the other sensors/ components but I thought maybe its not getting pressure because it’s not getting the correct signal from the PCM. However, I get a little over 8v from the FPDM fuel pump control wire and a little over 10v from its monitor wire.
I checked the PCM power wires of pins 35, 36, and 45, and I’m getting a 12v reading.
I just need some guidance in pin pointing which circuit is giving me the problem and I can take it from there. I doubt it’s the actual BEC that needs replacing but perhaps? I soldered all my splices and put heat shrink around them—pictures below of my solders—. I was very meticulous in this project so this is very frustrating as you can imagine.
^^No fuel pressure when in this position
^^This position I get pressure
