How Much Does It Weigh?
Fabman
Children Of The Corn
Pleasanton, Ca.
Yeah Im 260 so I feel your pain. Are you on E85? Is it anywhere close to you?
Yes, and there is one station close by, but out of my way, and on one of the on the busiest freeways in the bay area.
A 15 mile drive can be a couple hours round trip so I have drums of fuel stashed in my shop.
Stephen31201
That stuff is amazing on a blown motor. I just made the switch and cant believe the difference.
Stephen31201
^^^ So your belly swings huh? lol. Much of mine is in my lurch ass 6'4" Stature which makes me look like a Neanderthal in the car. Hence the name Neanderthal-Racing.com lol
Stock driveshaft: 37.3lb
Stock GT front rotors (pair): 37lb
Stock GT clutch assembly: 24lb
Stock GT flywheel: 22lb
18" Bullitt wheels: 25lb
255/45R18 tire: 26lb
Stock rear LCAs (pair): 14lb
Stock harmonic balancer: 10lb
Stock rear UCA: 4lb
Driveshaft Shop 3.5" aluminum driveshaft: 18.4lb
Steeda underdrive harmonic balancer: 9lb
BMR LCAs (pair): 7.2lb
746Watts
Anyone have weights on a 05-08 intake manifold with charge motion plates versus the 09-10 intake with the 100% plastic and cmcv assembly built in?
fordave
dna (ford)
ft myers fl
I will add a bunch of numbers to this tomorrow, I have a hand written sheet sitting in my car :)
thanks for the sticky Don
For some reason the list does not show up clearly its blurred, by any chance do you know the weight of the steel fuel tank ty
fordave
dna (ford)
ft myers fl
Matt D hasn't been here in years.
I did notice that I was hoping to get lucky
Hopefully someone can chime in and let me know the weight of that steel tank.
I was even considering going with the newer style plastic tank to shed some weight but that would require the replacement of the fuel hat that would cost another 1k
banzai_bullitt
Minnesota
** Note: scale is not accurate or does not weigh parts that are less than 5 lbs.
Steeda Parts:
- Part #: 555-5209
Jacking Rails (each): 7.2 lbs.
- Part #: 555-5551 3 Point Torque Box Frame Rail Brace (each): 5.6 lbs.
- Part #: STEEDA-1766-K Steeda Mustang GT 3.5" Aluminum Driveshaft (05-10): 20 lbs.
- Part #: 555-2550
Steeda S197 Mustang Race Adjustable Panhard Bar (05-14): >5 lbs.?
- Part #: 555-2555
Steeda Heavy Duty Chrome Moly S197 Mustang Panhard Bar Brace (05-14): >5 lbs.?
- Part #: 555-5075
Steeda Mustang Lightweight Radiator Support (05-10): 6.8 lbs.
- Part #: 555-5530
Steeda Mustang G-Trac Brace (05-14): >5 lbs. -> (4.2 lbs.?)
Other Parts:
- OEM Radiator support: 16.8 lbs.
OEM Panhard Bar Brace: >5 lbs.?
OEM Panhard Bar: 7.2 lbs.
OEM Driveshaft: 38.6 lbs.
OEM BULLITT Wheel 18"x8.5": 29.95 lbs.
OEM BULLITT Mufflers (each): 17.2 lbs.
FR500S Mufflers (each): 13 lbs.
MGW Short Throw Shifter 2005-2010 GT/V6: 5.6 lbs.
Blowfish Racing Shifter Support Kit V2: 9.2 lbs.
Midlife Crises
Fairbanks, Alaska
Using a bathroom scale ? A 2010 Mustang GT standard drivers seat ready to bolt in weighs 54.1 lbs. A Braum Racing Elite R drivers seat with slides and mounting bracket weighs 43.9 lbs.
moooosestang
Alachua, fl
Weighed my 2010 spare tire and it is 38 lbs, it is solid vice the 28 lb spares from previous years that has the holes in them.
My 245/45/19 Pirelli and rim weighs 59 lbs.
That must be a heavy rim! My 305/34/19 nitto nt555r2 and 19x11 shelby cs5 weight 58lbs. I should have weighed the front 19x9.5 with 265/40/19 nitto g2, but my back can testify that it's a lot lighter than the rears!
moooosestang
Alachua, fl
Weighed my stock leather seats. I know some have weighed them, but people got different weights. drivers seat power 55lbs, passenger seat 45lbs, can't remember if that was with or without wiring harness and buckle. I have the power lumbar as well, not sure if that's a separate option. My corbeau trailcats with brackets weigh 35lbs each, that's including the stock wiring harness and seat belt buckle. They could be 34 or 36 lbs, harder to weigh them on my bathroom scale because they are lighter and the scale is not digital. very noticeably lighter though.
JC SSP
FL
Those seats look awesome! Any issues installing them?
