blue3v
- Joined
- Dec 14, 2008
- Posts
- 104
- Reaction score
- 0
Tried to search it out couldn't find anything. Looking for info on timing chain install. Also be looking to do cams soon. Any help would be good parts advice etc.
Nothing really. I'm fixing to do a cam swap and figured it would be a good time to do it. The car has a little over 100000. I think 118000 to be exact I'll check tonight when I get home.
What about the lash adjusters and followers? Those are common wear items too.
My car has 80,000 miles, nothing shows any wear whatsoever in the timing system, it's really something. Mobil 1 5w20.
That said I'm installing the FRPP timing kit (including phasers,) I got for $150 Canadian pesos as I finish up the engine.
I believe if I were to replace the roller followers it is equally likely one or more new ones will be faulty as the ones currently in the engine, so no reliability can be gained by replacing these parts. They are probably good for several 100,000 miles.
You lost me here. How can a follower with 0 miles be as likely to fail as a follower with 80k on it? Are you saying 80k miles isn't enough to warrant changing them?
I ran my '09 F150 with a 5.4 for 380k without changing a thing.
Has it had a hard life? If it was boosted and raced like engines in our stangs the outcome may have been different.
I get what eighty6 is saying though. Without going full Jesel valvetrain, any factory Ford part, new or used, is a crapshoot.
Buy the kit and replace everything while you have it apart.
Don't fix it if it ain't broke. Now upgrading is a different story. I would just do the cams and drive it. Have fun either way and good luck.
