Spinks
Hobby Mechanic
Details: 05, GT, Manual, 160k, new OE clutch kit, Clutch master, slave.
I park in 1st gear with the ebrake pulled semi-tight (I'd like to get some longevity out of it).
My problem here is that if my ebrake didn't even work, my car should sit tight in 1st gear and not reverse itself out of my driveway, even at an incredibly moderate pace. I'm told I have low compression. I have yet to do a compression test. The car burns a bit of oil as well. The car drives and sounds fantastic. I let it warm up before I drive it every single time I take it out. I fill it up with mid-grade. I have only driven it wide open twice and I was told by the previous owner that taking these engines to their limit is really bad for them.
If someone could give me an answer as to why my car moves against the selected gear, that would be great. I don't know if this is a common problem or not. If I need to find a replacement 4.6 on Craigslist or something, what kind of money am I looking at? At the very least I'd like to perform an OE comparable rebuild and just drive my car as is in the meantime.
To make things clear: I'm not asking for a solution to keep my car from backing out. I can buy a chock for 5 bucks and I can pull my ebrake all the way up. I'd like to know why my car can't hold itself in gear without an ebrake or chock.
Thanks all!
Thanks all!
