Dylan is begging to help.
Gotta love that guy!
Rapture, feel free to give us a ring if you have any further questions brother. We are here to help!
Just go with poly then. I recommend our poly LCAs up to ~700 RWHP/RWTQ, so they'll be able to handle N/A with ease. If you plan on doing auto-x/road course stuff, it would probably be a good idea to grab a set of poly/bearing LCAs since lots of cornering will wear the bushings out quicker.
Panhard bar, either do a poly/poly bar or the poly/bearing bar.
You only need adjustable LCA if your thrust angle is screwed up from an accident or you're trying to compensate for launching with huge amounts of power.
I really don't think you need rod ends/spherical bearings.
My guess is that the poly/rod-end combination lets more differential gear noise into the cabin. Possibly some noise from clearance in the rod end as well (rattle). Not sure how the exact color matters here unless it's an indication of slightly different Durometer poly.http://www.americanmuscle.com/bmr-adjustable-panhard-poly-red-rod-0514.html
Is this the poly/bearing. Trying to figure out why it only has a few reviews and not so good ratings. Is it because it's not as comfortable of a ride ride compared too...
http://www.americanmuscle.com/bmr-panhard-rod-adjustable-poly-red-0514.html
Which has many many reviews and top ratings. Are those 2 both the same shade of red? Poly/poly looks darker.
A little more lead time for responses, please.Need to order today.
Doesn't really matter, as they'll need periodic re-lubing anyway.Do they come greased?
You don't have to unbolt one end to make adjustments. But with single-adjustables even if the nut/jam nut loosens up, the adjustment can't drift very far.What's the benefit of double adjustable?
Not necessarily. There are spherical pivots that are not rod ends.Is rod end, spherical, and bearing the same thing?
Or correcting pinion angle after significant lowering . . .You only need adjustable LCA if your thrust angle is screwed up from an accident or you're trying to compensate for launching with huge amounts of power.
Couple, maybe three times a year. Depends on how many miles you drive and probably on how many rainy days (or snow/slush if that's a possibility). I usually hit the greasable pivots (on my car that's the rear LCAs) once before track season and again around the end of summer. Maybe once more during a particularly active track day season (for me, that's a split season, before the second week of June and after Labor Day through December).Thanks Norm.
I noticed you said periodic and not frequent for greasing. Every oil change or so?
Sta-bar bushings/pivots if they're polyurethane or greasable. I use 3M silicone paste on the drop link bushings and bar end pivots (Strano/Hellwig bar).What else can I grease while I'm down there?
Not sure what I was using in the LCAs, but whatever it was I ran out of it last fall and haven't replenished the grease gun yet. Should probably put that on today's to-do list.Any preference for grease? I've heard some are bad for poly
Norm
PA adjustment at the UCA is certainly going to be simpler. Installation of the UCA itself, perhaps not, never mind that the articulation required for hard cornering argues against the use of polyurethane bushings (at either end of it, actually). That leaves some sort of spherical/spherical arrangement, which is probably too hardcore-race for most people.
Norm
A road course car is exactly what this OP is building . . .Honestly, most of the drivers out there will never have their car at the track
Sorry, I meant the same. ( however I change my post if it is dedicated road course car spherical all the way ) otherwise I'm still behind the poly/poly design.
