3c673cxao7l9o7u80ag8as1g2
Running Rich w/ Whipple **PROBLEM SOLVED**
**PROBLEM SOLVED**
The primary problem that ails me is that running the vehicle for more than an hour produces a too rich condition that affects drivability. I had an opportunity to install the AutoMeter Nexus Wideband A/F gauge and it only confirms the too rich condition. When my drivability problems begin, the numbers are off the chart, exceeding 20:1 (the limit on the gauge is 20). Carbon soot covers the back of the vehicle.
This problem presented itself immediately following the Whipple supercharger installation. I'm currently using the Ford Racing tune provided with the kit.
Some of you may recall my first major Whipple problem. The heat exchanger on the underside of the compressor was leaking coolant into the engine. Whipple rebuilt the supercharger and provided me with new spark plugs and two new fuel injectors. See this thread for more details.
The only check engine light that I was able to catch had something to do with the Fuel Rail Pressure sensor. See this thread for more details on that.
So at this point, what are the first steps to resolving this issue. Will a good tune fix the problem? If so, what is it about the tune that can remedy the issue? What does a good tune shop know that Ford Racing doesn't?
If it's not the tune, then what could it possibly be? Perhaps the coolant leak damaged the O2 sensors?
The fact of the matter is that I cannot drive the vehicle more than an hour. Seems like the only variable here is the engine temperature, as the vehicle runs fine after sitting overnight.
**PROBLEM SOLVED**
