Peter and I just replaced the BBR Regrinds with the BBR Billet cams and there seems to be a problem
The car will crank and start for about 1 second, then die. It wil lnot get to idle, just starts for a second then dies.
We removed the spacers from underneath the lifters, used new cam phaser bolts, torqued everything down to spec. There seems to be no logical explination.
We marked the timing gears, used the wedge to hold the chains, everything by the ford manual, step by step. Anyone who has changed cams pleae chime in
