| 2005+ Mustang GT 4.6L Tech Technical discussion about the 2005+ Ford Mustang GT 4.6L |
Thread Tools | Display Modes |
#1 |
Thought I would share my experience with this as some research on other forums yielded inconclusive answers. If this is common knowledge then please forgive me and ignore me (in that order, please).
I've been driving my new NA stroker around (no power adder but stroked guts, ported heads and cams) and all of a sudden it started going in to limp mode and throwing a check engine light. The scanner said P061b--the text around it is something like "torque calculation error". No other codes were thrown. Some quick forum searches showed folks with similar problems-- a lot with blowers and a few with bolt on parts. But no conclusive answers about what the problem is and what the fix might be. So I took the car in. One quick call to SCT from the shop owner and the problem was identified. An email with a patch to the tune was the solution. Loaded it up within 20 minutes and I'm good to go. No more trouble codes and car runs great. The best I can tell is that the ECM measures engine load (ie, "torque") along with several other variables to figure out the right injector pulse width. If the ECM detects that the engine is under more torque or load than a stock engine should be (e.g., with a blower or aggressive bolt ons) then the ECM will throw this code and send the car into limp mode. There is an easy fix for this in the tune--but not all tuners know about it. They just have to get the patch from the tuner co. Anyway, hope this is somewhat worthwhile to someone. Later... ![]() |
#2 |
The Evil One
Thanks for the info!!!
__________________
05 - Saleen S/C, Saleen suspension, 2.95" pulley, Livernois heads, Thrump_rrr tensioner etc. http://www.fquick.com/ZmanM3 |
#3 |
Giggity Giggity Goo
That's good to know. Thanks!
__________________
http://www.myslips.com/eslip/2005turboGT.jpg 2005 GT Turbo - "Cujo" http://img.photobucket.com/albums/v6...1m_8d4da52.jpg |
#4 |
Good tech info on that problem, thanks
You have a stroker, what CI are you at now?
__________________
07 Redfire GT C&L Racer CAI/SCT XCAL2/Sequential Turn Signals/GTA Mufflers/Steeda UDP/ CHE K Member Brace W/Torque Links/Steed Air/Oil Separator/PRO 50 Shifter/J&M LCA/Spider D/S /Meziere Elect. O2 pump/AHR Long Tube Headers Catted H Pipe/Prothane MM/Boss 429 Hood Scoop/Ducktail Spoiler/Tokico D-spec/Steeda Adj Pantard Bar/CHE Pantard Bar Brace & Adj UCA/BMR UCA Mount F&R Sway Bars Tillman Speed Dyno Tune 307 rwhp & 322 rwtq |
#5 |
DUDE!! i have an 08 bullitt, comp stage 2 thumper cams, steeda udps, pypes shorty headers, off road "x" pipe, flowmasters and charge motion delete plates and a twin 62mm bbk throttle body
. im using a diablo sport tuner, gettin the same code EVERY TIME I DRIVE THE CAR so, you are telling me ditch diablo and call sct and its fixed? please let me know asap, thanx |
#6 | |
i love my cams
Quote:
__________________
4.56s, hooker lt's, off road x, airaid cai, pro 50, pro kit, adj panhard, adj lca's, relo brackets, 1 pc al ds, udp's, frpp cams, cmcv deletes, ds loop, d specs, et streets, j&m uca, detroit truetrac, 2 step, 12.39@107.9 |
#8 |
Can you give me some more info about on code p061b? I have been having crazy issues with this code. I replaced my TPS on my 2007 stang and now I am getting this code, if you have any more info on this code please let me know.
#9 |
The function that needs to be changed has the word "quizzer" in it.... I dont recall exactly what is says but as soon as I get my commando software loaded up I'll let you guys know. Any software can adjust this, its just in an obscure area. I have to fax in my user agreement so it will be a couple of days before I get the exact funtion name for you.
__________________
Holcomb Motorsports BOSS Big Bore build in progress along with a manual to auto swap. FB Performance 4STB w/ all the upgrades. |
#10 |
I love Red Bull
Ah. So thats what the code means. I got this at the track twice in one day and called it a day but after that, I never got it again
__________________
Magnapac exhaust, BBK LTs, O/R X pipe, Ground Force springs, Bullitt Rims. Saleen S/C, 3.2 pulley, GT500 pumps, BA2400 MAF on Saleen Extreme intake, 60lb injectors, FRPP TB, Autometer digital cobalt wideband, boost fuel pressure gauge in SOS pod, BMR LCA,UCA, adjustable panhard, 4.10s, PH D/S, Hot Rods |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
