3c673cxao7l9o7u80ag8as1g2
The bypass actuator on my Whipple supercharger is making an audible high pitch whine.
I used an automotive stethoscope to pinpoint the source of the noise, and every indication is that it's coming from the bypass actuator. Also, when I unplug the vacuum hose that connects from the compressor housing to the bypass actuator, the noise stops.
1. Any ideas what the problem might be specifically? Can I repair it myself?
2. Also, does Whipple use a common bypass actuator? Such as one from Eaton for the GT500, etc.?
