- Joined
- Sep 15, 2007
- Posts
- 3,065
- Reaction score
- 5
JDM ENGINEERING
302E Stroker 3v Shortblock
When it comes time to build an engine for your Mustang, experience and quality should be the first things that come to mind. JDM Engineering has been on the fore front of modular engine building since the early 90’s when the motors first debuted. With nearly 20 years experience building mod motors and thousands of satisfied customers across the world, Team JDM is one of the top names in the industry. When your looking for a custom built engine, Team JDM has the experience and quality your looking for!
Get ready for a 1000hp rated short block that utilizes a 302 rotating group to increase your maximum power output! These top of the line built bottom ends come pre balanced and fully assembled to JDM spec. Based around the production 281 platform this 302 motor utilizes a brand new Ford Racing 4.6 block. The FRPP block is known to be the strongest 4.6 Aluminum block ever in production by Ford. Extra displacement comes from the rotating assembly which includes a steel forged stroker crank shaft. Custom stroker rods, JDM spec pistons, coated rings and premium bearings are also included. Compression is left stock in order to achieve peak power and performance. The short block is tied together with brand new fasteners and bolts, guaranteeing strength and integrity of the engine. Every engine is hand built and assembled in an engine clean room to ensure quality control.
These are some of the same spec components used in JDM Engineering race cars campaigned in the NHRA, IHRA, and NMRA Drag race series. Not only have these engines been tested on drag race vehicles but also SCCA and Open track event cars which run in the most extreme conditions. With a combined 70 plus years of experience, Team JDM can provide you with the quality and performance that your looking for. Every engine is backed up with a 1 year warranty, something that you will not find offered by most performance shops.
JDM Stroker 5.0L Mod motor specs:
302 CID Modular 2v, 3v, and 4v
3.554”Bore x 3.800”Stroke
Stock compression (9.8:1)
New FRPP Aluminum 05+ Block plate honed for a truer bore geometry
Speed Pro NASCAR bearings
JDM Spec Ring pack w/ Stainless top rings for better seal and longevity
JDM Spec Kellogg forged steel crankshaft
Induction hardened journals and 8 bolt flange
JDM Spec custom forged CP pistons
Manley Forged steel 4340 connecting rods w/ ARP fasteners
Jim D'Amore III
JDM Engineering
732-780-0770
[email protected]
$3499.00
1000 HP Rated!!
1 Year warranty (no detonation)
1000 HP Rated!!
Jim D'Amore III
JDM Engineering
732-780-0770
[email protected]
