tmcolegr
It's All About the Build
So after reading every thread I could find on this forum, and every other forum, I placed my order for a 913A561 Detroit True Trac. Just about every thread I read discussed the C-Clips being a PITA to either install or remove after installation and most everyone has stated they had to grind the spacer that is included with the True Trac. I also see Jeg's website states "2005 and up Mustang requires axle spacer modification." So I placed a call to the manufacturer and received a verbal explanation as to why we are having difficulty installing the spacer. Seems in 2005+ Ford decided to narrow the axle housing on the S197s. Tech support also mentioned the pinion shaft is slightly smaller on the OD to accommodate this narrower axle housing.
So here's my question: has anyone measured the axle end play on a stock S197 8.8" axle assembly? If I'm understanding how this set up works, the C-Clip touches the side gears when the axles are pulled outward and the pinion shaft when the axles are pushed inward. If this is truly the case, it shouldn't be too hard to take that same end play measurement and machine the True Trac axle spacer with a magnetic surface grinder to achieve the same axle end play once the True Trac has been installed. This would also eliminate the C-Clips being a PITA to install.
Can anyone confirm this or am I full of shit?
