hey guys,
just wanted to let you guys in on some info as i am getting close to finalizing the testing and design of our 2011 shifter.
first... the THROW....
as you guys know that have your cars already the new stock tranny is kinda odd in that the side to side travel is VERY short while the front to back is not as short as it should be but close....
this is just the way it was designed sooo...i originally designed the shifter much like our corvette shifters to have a double pinion design rather than a pivot ball to shorten the throw front to back and not side to side...i was shooting for about 30-35 percent reduction in throw....
NOT A GOOD IDEA...
apparently the new tranny that ford is using is not as robust as the TREMEC was and we have found that anything more than about 15-20 percent reduction in throw is going to have issues with lockout and also wear on the synchros of this transmission. i have been testing and researching this transmission for a LONNGGGG time and talked with various engineers on this project so i am VERY firm on my opinion of this.
after trying countless combinations of shifting throws i decided that to be honest the THROW of the oem unit is not that bad and actually for both roadcourse and drag racing the effort is pretty spot on...
BUT.where the factory unit falls flat on its face is DEFLECTION!!! it is HORRIBLE!!! the stock box UNDER the shifter has to be replaced and the rear support bracket is a joke!!! it has zip ties around a rubber mount for petes sake!!!
so in the end what i am designing is going to be basically a 15-20 percent reduction with ADDITIONAL spring back to neutral for the drag racers out there. with a COMPLETE replacement to the entire unit under the boot.
so if you guys are hung up on a super short throw then you might want to look elsewhere BUT i can assure you the shifting will be faster with our setup
stay tuned for more info and pics around the holiday break!!
george
NOT A GOOD IDEA...
george
