The "how much it weighs" thread
ocpony
Circle D convertor with fluid, 2C version weighs 38.5 #
Stock front springs 12# pair. Rear spring 10.5# pair.
H&R rear springs with height adjusters. 12# pair. 29170 part number.
GeorgeInNePa
Clarks Summit, PA
I know some of these have been covered, take this as a confirmation.
All items weighed on an older 30lb capacity Digital Deli Scale.
Engine Cover--------------------------------3.09lbs.
Grill w/lights (surround not included)----------3.47lbs.
OEM Panhard Rod----------------------------7.30lbs.
Jack, Wrench, accessories-------------------5.42lbs.
Spare Cover/Trunk Floor---------------------6.80lbs.
Sound Tube & Isolator-----------------------1.19lbs.
Drivers Side Shortie------------------------10.72lbs.
Passenger Shortie--------------------------11.01lbs
OEM H-Pipe & Clamps------------------------9.49lbs. ---->50.15lbs total
Drivers Side Cat-----------------------------9.45lbs.
Passenger Cat-------------------------------9.48lbs.
Front Sway Bar & Fasteners-----------------15.80lbs.
Z-Brace & Fastebers-------------------------5.86lbs.
^Plastic Shield-------------------------------1.66lbs.
JPC Driver Side LT Header-------------------13.71lbs.
JPC Passenger LT Header--------------------14.23lbs. -----> 38.76lbs total
Corsa 2.75” X-Pipe & Clamps-----------------10.82lbs.
I could not weigh wheels/tires, spare, OEM torque converter, or my Circle-D converter. They were all over 30lbs.
eric n
I tried mine out with known weights (weight lifting weights) and it was dead on at 10 pounds, and off by about a half pound at 5 pounds.
For really light stuff, you'd need a small food scale.
As a note weight lifting weights are not always accurate. They have been horribly inconsistent. 10+ % differences are commonplace.
GeorgeInNePa
Clarks Summit, PA
OEM Cold Air, filter, and air box....6.07lbs
OEM LCAs, ..............................5.82lbs x 2
J&M poly/poly LCAs ...................3.60lbs x 2
UPR 05-10 UCA-adjustable, .........4.89lbs (no hardware)
JPC 2011 UCA,...........................2.89lbs (including 3/4" nut and bolt)
OEM LCA,.................................4.85lbs (including nut & bolt)
Axle Weights- Both,...................4.93lbs
2011 Rear Seat Base,...............12.65lbs
Wnt2gofst
Banned
Columbus GA
So i see my back seats must go. They weigh over 12lbs...lol
beefcake
Forced Induction Specialist
Bethel, Ohio
manual cloth seats. 44.5lbs each.
swapping both saves you 33.5 lbs each over premium for 67lb weight savings. I would say the rear closth seats have to be 1-2 lbs as well.
steveespo
Brembo front rotor 25 lbs, rear rotor 12 lbs. DBA 5000S Slotted/Drilled 14" rotor 21 Lbs, Baer Eradispeed 14" rear rotor 13.6 lbs.
2011/5.0
Iowa
stock front rotor 20.5lbs
weld rts 17x4.7 17.5lbs
m&h racemaster 185/55/17 17.5lbs
COYO TT
Stangless
Annapolis MD
Anyone have the shaker 1000 and remove the rear subs and weigh em? I will once i find a worthy scalr lol
Also want to know. Did a google search and someone said 40lbs. And the shaker 1000 system as a whole is 70lbs over a base model, and 47 over shaker500. :ugh1:
COYO TT
Stangless
Annapolis MD
I removed it. Mine only had one amp on the back of it. Its not as heavy as i woulda thought, but still about 30lbs
