| 2005+ Mustang GT 4.6L Tech Technical discussion about the 2005+ Ford Mustang GT 4.6L |
Thread Tools | Display Modes |
#1 |
cleaning out your closet
Technical Service Bulletins
2005 MUSTANG - US (English) 05-10-19 INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS 05-9-18 DISCHARGED BATTERY - CHARGING SERVICE TIPS 05-9-15 MIL AND ETC LAMPS ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR 05-9-14 CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS 05-9-11 FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005 05-9-3 INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS 05-8-8 GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 1/15/2005 05-8-6 EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION 05-7-3 AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004 05-6-15 AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004 05-4-8 FUEL FILL SLOW, OR DIFFICULT TO FILL 05-3-1 MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM) 04-26-22 MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE 04-26-16 WELD BONDING PROCEDURE 04-24-20 LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS 04-24-14 GENERAL PCM PROGRAMMING PROCEDURES 04-24-5 REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR 04-16-1 ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS 04-14-7 SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS 04-9-6 BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION I will update this more this afternoon.
__________________
#2 |
Guest
2005 MUSTANG - US (English) UPDATED: 6-15-06 06-14-3 AIR CONDITIONER COMPRESSOR CLUTCH FAILURE - REVISED COMPRESSOR CLUTCH 06-12-11 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS 06-10-13 MIL P0463 OR ERRATIC FUEL GAUGE 06-10-10 AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES 06-10-1 AIR CONDITIONER COMPRESSOR CLUTCH FAILURE - REVISED COMPRESSOR CLUTCH 06-9-9 HESITATION ON ACCELERATION AFTER LONG CRUISE 06-7-10 MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020 - 4.6L 3V 06-5-4 PARK BRAKE CABLE FREEZING/REAR BRAKES DRAGGING 06-4-9 A/C COMPRESSOR NOT OPERATIONAL / LOW FREON - SHAFT SEAL LEAKS 06-4-7 TICKING AND/OR KNOCKING NOISE FROM ENGINE - 4.6L/5.4L 3V 06-4-2 BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS 06-4-1 RATTLE/NOISE FROM THE CENTER STACK (RADIO/HEATER) OF THE INSTRUMENT PANEL OR GEARSHIFT AREA 06-3-13 FUEL FILL SLOW, OR DIFFICULT TO FILL 06-2-9 DTC P0340/P0344/P0345/P0349 - 4.6L 3V AND 5.4L 3V 05-24-6 CONVERTIBLE SYSTEM CONCERNS 05-22-8 WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING 05-21-2 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS 05-20-2 REAR AXLE NOISE 05-19-10 LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT 05-18-10 BRAKE NOISE - VEHICLES BUILT BEFORE 3/8/2005 05-16-12 SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS 05-15-13 FRONT SIDE MARKER LAMP RETAINING TAB BREAKING 05-15-12 FUEL FILL SLOW, OR DIFFICULT TO FILL - VEHICLES BUILT BEFORE 4/26/2005 05-15-8 TICKING AND/OR KNOCKING NOISE FROM ENGINE - 4.6L/5.4L 3V 05-15-2 GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 2/21/2005 05-14-4 WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR 05-10-19 INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS 05-9-18 DISCHARGED BATTERY - CHARGING SERVICE TIPS 05-9-14 CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS 05-9-11 FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005 05-9-3 INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS 05-8-6 EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION 05-7-3 AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004 05-6-15 AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004 05-3-1 MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM) 04-26-22 MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE 04-26-16 WELD BONDING PROCEDURE 04-24-20 LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS 04-24-14 GENERAL PCM PROGRAMMING PROCEDURES 04-24-5 REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR 04-16-1 ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS 04-9-6 BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION |
#3 |
Guest
2006 MUSTANG UPDATED: 3-17-07 07-5-13 DISCHARGED BATTERIES - VEHICLES IN STORAGE/LIMITED USAGE 07-5-8 BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS 07-4-3 LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE 07-3-9 MIL ON - DTC P0456 07-1-7 MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS 06-26-2 CARPET REMOVE AND REPLACE 06-26-1 MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS 06-25-15 ALUMINUM BODY PANELS - CORROSION - SERVICE TIP 06-22-18 POWER WINDOW DIAGNOSIS 06-22-16 CONVERTIBLE TOP WEAR - BUILT BEFORE 10/11/2006 06-21-19 HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY) 06-21-7 AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES 06-19-12 DTC P0340/P0344/P0345/P0349 - 4.6L 3V AND 5.4L 3V 06-19-2 8.8 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS 06-18-16 IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES - SERVICE TIP 06-17-8 SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS 06-15-8 KEYPAD DIAGNOSTICS - DEALER INSTALLED ACCESSORY 06-14-3 AIR CONDITIONER COMPRESSOR CLUTCH FAILURE - REVISED COMPRESSOR CLUTCH 06-12-11 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS 06-10-13 MIL P0463 OR ERRATIC FUEL GAUGE 06-10-10 AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES 06-10-5 5R55S - TRANSMISSION FLUID LEAK 06-10-1 AIR CONDITIONER COMPRESSOR CLUTCH FAILURE - REVISED COMPRESSOR CLUTCH 06-9-11 LOUD TICKING NOISE - 3-VALVE ENGINES - STUCK LASH ADJUSTER 06-9-9 HESITATION ON ACCELERATION AFTER LONG CRUISE 06-7-10 MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020 - 4.6L 3V 06-5-4 PARK BRAKE CABLE FREEZING/REAR BRAKES DRAGGING 06-4-2 BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS 06-4-1 RATTLE/NOISE FROM THE CENTER STACK (RADIO/HEATER) OF THE INSTRUMENT PANEL OR GEARSHIFT AREA 06-3-13 FUEL FILL SLOW, OR DIFFICULT TO FILL 06-2-9 DTC P0340/P0344/P0345/P0349 - 4.6L 3V AND 5.4L 3V 06-1-5 DTC P1000 MAY NOT CLEAR IN HIGH ALTITUDE CONDITIONS 05-24-6 CONVERTIBLE SYSTEM CONCERNS 05-22-8 WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING 05-20-2 REAR AXLE NOISE 05-18-7 WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS 05-16-12 SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS 05-9-18 DISCHARGED BATTERY - CHARGING SERVICE TIPS 05-9-3 INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS |
#4 |
Guest
2007 MUSTANG UPDATED: 3-17-07 07-6-7 SPOILER/DECK LID CONTACT 07-5-13 DISCHARGED BATTERIES - VEHICLES IN STORAGE/LIMITED USAGE 07-5-8 BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS 07-4-3 LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE 07-1-7 MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS 06-26-2 CARPET REMOVE AND REPLACE 06-26-1 MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS 06-25-15 ALUMINUM BODY PANELS - CORROSION - SERVICE TIP 06-25-3 PIONEER NAVIGATION RADIO - SEEK FUNCTION INOPERATIVE - SERVICE TIP 06-22-18 POWER WINDOW DIAGNOSIS 06-22-16 CONVERTIBLE TOP WEAR - BUILT BEFORE 10/11/2006 06-21-19 HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY) 06-21-7 AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES 06-19-2 8.8 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS 06-17-8 SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS |
#5 |
Guest
Here are all 2005, 2006 and 2007 Ford Mustang TSB's.
2005 Ford Mustang TSB's 2006 Ford Mustang TSB's 2007 Ford Mustang TSB's Something like this, now you can make this a sticky and then when someone wants to check out TSB's they can just click this sticky and find all their needs. Feel free to edit this as you need to. Casper |
#6 |
One of the "bad guys"
04-9-6
Body - Paint - Iron Particle Removal - Industrial Fallout - Acid Rain Neutralization
__________________
![]() Some people are like Slinkies. They're really good for nothing. But they still bring a smile to your face when you push them down a flight of stairs. "The reason people use a crucifix on Vampires is because Vampires are allergic to bullshit" "Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end." |
#7 |
04-14-7
Service Wiring Harness Replacement Guidelines - Service Tips
__________________
#8 |
04-16-1
Engine Misfire Or Rough Running - Coil On Plug (cop) Ignition Systems - Wds Cop Kit Diagnostic Tips
__________________
#9 |
04-24-5
Rear Window Defroster Grid/integral Antenna Diagnosis And Repair - Terminal Tab Repair
__________________
#10 |
04-24-14
General Pcm Programming Procedures
__________________
#11 |
04-24-20
Limited Slip Axle Chatter, Shudder, Binding Sensation, Or Vibration During Low Speed Turning Maneuvers
__________________
#12 |
04-26-16
Weld Bonding Procedure
__________________
#13 |
05-3-1
Maf Diagnostic Service Tip - Vehicles Equipped With Egr System Module (esm)
__________________
#14 |
05-4-8
Fuel Fill Slow, Or Difficult To Fill
__________________
#15 |
05-06-09
Intermittend CD Player Concerns
__________________
#16 |
05-6-15
Air Bag Warning Lamp On - Dtc B1891 In Restraints Control Module Or Lamp Flashes Code 53 - Vehicles Built Before 10/02/2004
__________________
#17 |
05-14-04
Wrench Light On With Both DTC P2106 And P2135 - Vehicles Built 11/29/2004 And Prior
__________________
#18 |
05-7-3
Axle Whine - Vehicles Built Through 11/15/2004
__________________
#19 |
05-8-6
Exhaust Vibration At 850 Rpm - 4.0l Engine And Automatic Transmission
__________________
#20 |
05-8-8
Growl/grinding Noise In 2nd Or 3rd Gear During Deceleration - Tr3650 Manual Transmission - Vehicles Built Before 1/15/2005
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| STI VS MUSTANG aka brother vs brother | KILLER06GT | Kills! | 26 | 07-15-2007 05:31 PM |
| Not Mustang having peeps post here... | GTO4Life | Pitstop | 23 | 04-08-2007 06:50 PM |
