BMR Suspension
Handling A-arms for the 2005-2009 Mustang
Correct the suspension geometry on your lowered S197 Mustang with a set of Handling A-arms from BMR Suspension. Based on our well proven traditional A-arm design, these Handling A-arms feature ¾” taller ball joints to raise the roll center height on lowered vehicles for improved handling. The BMR Handling A-arms are constructed from heavy duty 1.25” DOM tubing and feature laser cut, double-gusseted reinforcement plates. The non-adjustable A-arms (AA023) include a combination of low-deflection, internally-fluted, polyurethane bushings and fluted, greasable, Delrin bushings. The adjustable A-arms (AA024) include Delrin bushings and Teflon-lined XR series spherical rod ends with stainless spacers. The result is a high quality tubular A-arm that minimizes bushing deflection, reduces unsprung weight by up to 11 pounds, and improves handling by reducing body roll. Installation time is only 3 hours. Available in black hammertone or red powdercoat.
