Synister500
I've read some people have had some issues with the Whipple Single Blade TB, but do any of you have any experience with their twin 75mm TB. Chris Jones is my tuner and we have tried multiple times to correct this with the tune but I am still having issues. The setup is a Whipple 2.9 with the crusher intake, JLT 127, Whipple TB, 3" pulley, ThumpRRR tensioner, kooks 1 7/8" LTH, O/R x-pipe, custom 3" exhaust to mufflers, 72 lbs injectors, Afco dual fan HE, 170* thermostat, and expanded coolant tanks. For some reason I only see about 14-15psi max boost at WOT (aftermarket gauge). I have ruled out any vacuum, intake and exhaust leaks just to be sure. Here is the problem, The car is running a little rich (we know that from data logging, car was tuned at the track while BBR was in Bowling Green for NMRA, not on a dyno) but every now and then the RPM will hang up around 2k rpm when coming to a stop. It is very aggravating and makes you feel like a jackass. I'm down to the point of using a different TB. I have a L&M 72mm on the way here (only thing I could get in black). Have any of you experienced the same problems or know someone who has? I've read its the tune just as much as I've read its the TB. I know this TB is too big for my set up but whipple sent it with the SC. Any help would be greatly appreciated. We have tried multiple tunes and I think it could a mechanical problem like the TB is physically sticking open after I have let out on the pedal. I can't imagine a way to actually check this though, I'm afraid it might screw up something allowing unmetered air into the intake. Also, does the amount of boost I'm seeing seen right (I imagined it would be closer to 18 with the CAI, TB, and intake). At idle it holds about 22psi of vacuum.
BJ
BJ
