Well after selling the K/B Mammoth I’m getting started on returning to my first love…
Ready to get started on the Big Block Ford. This car will be a little different than some we have seen
This will not be an all out race car…It will be 90%
The other 10% will be for cruise in’s or fun ford weekend/truestreet type events. Its gonna be a truestreet car. That said things like A/C are optional (“ not gonna do it; wouldn’t be prudent at this juncture”) and an alternator is mandatory. Basically the car will loose all the factory wiring under the hood ( save for the lights) and retain most inside. I’m going to tuck the factory fuse box back where the stock battery location sits. So I will retain power windows, locks, light ect. The speedo and Tacho will not work but I’m working on what to do there…since I already have an old school Tach on the dash it should prove interesting.
I’m also considering whether to put the remainder of 8.99 roll bar in or remain outlaw. I currently am only good to 9.99 (10.00 6 point)
The car will have a glide…It is being built here in Alabama by Lane at PTC. Will have a Reed case and JW bellhousing so that I wont need any shield or diaper.
The engine is also being built here in Alabama by Bennett Racing engines. This will be a 600 CU IN Big Block Ford. 4.60 bore with a 4.50 stroke. I will be using the A-460 block and heads will be of the same variety…A-460 TFS with A-460 TFS intake single plane. The carb will be Pro system Dominator
The reason I’m going with a bigger bore is to get as much power as possible with lower compression. This will be 11.5:1 or 12:1 and gonna work real hard to make it pump gas…BTW…975 hp on pump gas…all motor. Should run in the bottom half of the 9’s
Scat Crank and Rods, Kasse oil pump, Danny Bee timing gear belt drive.
Ignition will be MSD digital7 and timing trigger wheel
I hope to keep my power brake ( somehow )
Exhaust will be 2 1/8” stepped to 2 ¼” headed to 4” collectors
I plan to run twin shrouded fans to keep it cool
I will also run a fan on the tranny cooler.
I removed the factory fuel tank and will run a 15 gallon sumped tank in the trunk.
The fuel pump is the magna fuel prostar 500 with built in bypass return
Will post pics and lessons learned as they occur...
Prepping engine bay for paint:
