2DaDarkZide PR
Vroom, Burble, Burble
http://youtu.be/PyXxC5hd5_E
I installed J&M lower control arms which are half working because they need a relocation bracket to adjust the tilt from lowering the car. In using the relocation brackets, I CAN lose some braking ability and cornering ability.
Those are 2 things I am not willing to sacrifice so it is what it is. I also installed a Freedom racing pan hard bar to line up my rear properly as the stock one shifted when I lowered it. It was visually noticeable even with my 1" drop. This reduced my spin in 2nd down to an acceptable chirp. Also COMPLETELY killed the fish tailing in 2nd.
I will no longer heat up my tires as the general consensus seems to be my Nitto 555s work better at ambient temperature. So I was hurting myself by burning out this entire time.
I will give it another go probably Sunday, the 7th.
I did not get 12's. I managed to best my previous time just slightly from a 13.122 to 13.115. I just want a 12.9XX or faster and I will be happy.
Slip up tomorrow. All runs in the video, though.
To clarify by "street car" I mean a car with full weight, spare and street tires. No weight reduction, no slicks/radials etc. At 107.60 and 107.80 I feel there is at least a 12.9XX in there somewhere.
EDIT: By street tires I mean no 'R' compounds or DRs.
