hunterwiley
I race in American Iron w/ NASA - MidAtlantic, and until recently raced a 88 foxbody with a 342 small block stroker. AI is a HP and Tq limited class, based on total weight and whether you run ABS or not. I picked up an 05 caged car with plans to eventually swap out the 4.6 to my 342 over the winter. A broken transmission (T3650 stock) moved the drivetrain swap up a bit...
The swap will be slow, but should move a bit quicker once I get my oil pan modified and the headers arrive. I'll be using an external oil pump so the front sump on the oil pan will be cut off, clearing room for the engine to sit further back behind the rack. Here's a couple of pics showing the difference in size between the two engines. It's more striking comparing a empty 302 block to a fully dressed 4.6 engine, but it's an impressive difference in size!
Before...
Currently w/ a bare 302 block sitting on jacks and blocks. The front of the block is spaced 4" off the rack/k-member, as the front of the pan will be ~3.75" deep. I'm waiting for the mid-length headers to arrive (Doug's Headers) then will weld up some mounts that's clear the steering shaft.
Should be a pretty cool car once she's done... My stroker engine made around 340rwhp and 360rwtq with a restrictor plate in the fox. Should be just about perfect for the 05's weight...
Before...
