swflastang05
Back for More
Well lookie here what finally got done this week, or at least some of it got done. I have the short block but it turns out the oem valve seats are too small for the over size Manley extreme duty valves that I ordered so my machine shop had to order all new over size seats, they should arrive tomorrow then they can install them and finish the valve job, hopefully I'll get my heads back in a few days.
Round #4 officially begins now:
The sleeve was installed in #5, look how big it is compared to the oem sleeve! My machinist said it was a real PITA to bore it out too, the material is way harder than the oem stuff.
Crank is in it's new home, end play came in at .006 this time.
PTW is .0045 to .0050 on this motor, a little looser than previous motors. Main bearing clearances are a little looser too than my previous motors at .0026 - .0028, rods are the same .0025.
Spent some time admiring these new pistons, I literally only had them in my possession for a few minutes before I brought them to the machine shop, they are damn sexy!
Ran into a snag with the piston rings not having enough side clearance with the piston so I get to bring them back to the shop tomorrow to get clearanced. Range is .0015 to .003 and I can't get my .0015 feeler gauge in there so she's too tight!
