What parts would you like made for your S197?
eighty6gt
Why don't YOU walk? I'll walk! It's not a far walk, it's only 38 miles!
eighty6gt
I don't really like the look of deck lid panels.
fdjizm
Drag Queen
Some proper axle tube braces, a really good substitute for welding.
eighty6gt
heh, I think once I make a few and they get out in the world people might start trying to find me. I guess I should put a label on them. Maybe laser scribe.
bujeezus
Alabama
I think that looks pretty damn good! How about a Bullitt emblem without the key hole then? Wait! How a bout a flush cap to replace that wart on the trunk (antenna)?!?
Dad
SW KY
A quality replacement for that plastic crappy cover around the auto shifter. You know, the thing that slides front and back with the shifter, no idea what it's called other than broken.
eighty6gt
Flush cap is a great idea!
They already have custom fake fuel fillers. I'd need to license something bullitt specific.
stv_huff
Stock
TX
I call mine the hot hole.
eighty6gt
I will have to find an automatic S197 or order an auto shifter on ebay to make the hot hole part.
Almost ready to ship these guys... 16 lb! Might make them a bit lighter.
Wheel spacers, 6061-T6, hubcentric, with the chamfered inboard edge for the hub, and only 5 precise, snug fitting lug holes. Offer em in 1-2-3-4-5.....20mm thickness. IE: 1mm increments. Build to order. The S197 uses 1/2" (12.7mm) lug holes. 5 x 4.5" bolt pattern. 70.5 mm bore. The S550 uses 13mm holes. Everything out there has either 10 x lug holes, or is not hubcentric, or way over priced, or not chamfered, or oversized lug holes, slots used. Then make em for ricers, euro trash, and GM / Mopar. HR wants like $70 for a 3mm hubcentric spacer pair... which is beyond nuts. Offer en in singles, in case somebody trashes one.
eighty6gt
yes - splitter I need to have my front clip on so I can mock it all up, build the parts, make sure it doesn't look stupid.
eighty6gt
For me to do this would be about $250 each
