Gt500 Fuel Harness
TzReddy
Florida
I bought his harness used and I have a gt500 fuel hat. 2 wires are cut on the harness and was wondering where they go. Also seeing both are gt500 harness and hat the plug is direct but the plug on the outside of the cover I am assuming gets wired to the original plug from stock harness. Do they sell a diy plug for that or can I just solder them together and if so which wires go where?
slackinoff
East Texas
I don't know much about this, but the cut wires look like positive power. If so, I think I would soldering them. Not sure on the plug.
Sent from my SAMSUNG-SM-T377A using Tapatalk
DiMora
More Is Better
Fayetteville, GA
The seller might've had a Kenne Bell or other brand Boost-A-pump wired into there also...which may throw you off with pieces of wire that are different colors
ILW84U
Edmonton, Alberta
The wires in the first pic just need to be soldered back together. They are the power wires to the FPDMs. The larger plug goes to the fuel pump & the smaller 2 wire plug goes to the crossover pump on the passenger side saddle of the fuel tank. There are 2 wires that need to be crossed over on that plug. I can grab the instructions for that later & post them if you need.
TzReddy
Florida
If you can that would be great
TzReddy
Florida
Do I have to extend the wires on the 2 wire plug to reach the passenger side?
TzReddy
Florida
The stock plug and the 2 wire plug in the picture aren’t the same. They won’t plug into each other. Do I need to buy a different plug to rearrange the wires?
ILW84U
Edmonton, Alberta
I did mine 8 years ago but I am pretty sure the plug was the same. Maybe someone else can answer.
TzReddy
Florida
I would just solder and get on with it man
Thats what I am going to do. I will line up the 2 wires from the gt500 harness with the 2 wire plug and pull the 2 wires out of the original harness and solder together. Hope they line up right as Ive read that the Ford directions are wrong on the color cordination
slackinoff
East Texas
Oh damn, well if you can't find anymore research on the colors. At least it's a 50-50 odds. If it's wrong hopefully it only throws a code or something. Worst would be to burn up a controller. Wish I had more info for you.
TzReddy
Florida
I believe if its wrong it only shows false reading on gas gauge.
