Saleen Series VI S/C Maintenance Manual
tmcolegr
It's All About the Build
Central, FL
Today I received a Saleen Series VI S/C Maintenance Manual. Unfortunately it isn't in a PDF. Here are the highlights.
SALEEN SERIES VI SUPERCHARGER FOR 2005-07 MUSTANG MAINTENANCE SCHEDULE
Very little maintenance is required for your Series VI supercharger. There are two key fluids involved in the kit which you should pay attention to. Please hold on to the installation manual for the supercharger kit to aid in the location and identification of the components
1. The oil in the front (gear case) of the supercharger is refilled via a brass plug on the driver’s side. The plug is underneath the water crossover of a completely installed kit. The supercharger takes a full pint of oil. The oil that the supercharger is delivered with will last 50,000 miles. A 5W-50 oil may be substituted but will need to be changed every 5000 miles. When changing the oil, be sure to completely siphon all of the oil out of the gear case.
2. The supercharger kit comes complete with an independent coolant system. Regularly check the fluid level of the intercooler system. The fluid should reach the bottom of the neck of the recovery tank when the system is cold. With the water pump on (key on or car on), check as often as every couple of oil changes that the fluid is circulating. If it is not, purge the system per the instructions in the supercharger installation manual.
Change the fluid in the intercooler system as often as the radiator fluid is changed, using a 50/50 mix of antifreeze and water.
If you have any questions, please call Saleen at 800-888-8945.
*note: there is no warranty on the supercharger in the aftermarket unless supplied by the installer.
Communication With a Saleen-Calibrated PCM (Powertrain Control Module)
·The PCM in each Saleen vehicle is programmed with specific performance and calibration data.
·Saleen-programmed PCMs have a unique “PCM ID” number. This number can be found on the Saleen label affixed to the PCM or it can be looked up using a diagnostic tool (IDS, WDS, or NGS; for 2005 and newer vehicles [except S7] always use IDS if available). All Saleen PCM ID numbers end in “.HEX”
·PCMs in Saleen vehicles can ONLY be re-programmed (re-flashed) by Saleen. If re-programming is needed, the PCM must be sent back to Saleen.
·A P0605 DTC will be present in each Saleen-programmed PCM. This code can not be permanently cleared.
·When using an IDS or WDS diagnostic tool to access Saleen-programmed PCMs, the tool may prompt you to upgrade the PCM to the latest Ford stock program. DO NOT DO THIS. If the PCM is programmed to the Ford stock program, or any other program, the engine will not run properly and Saleen will void the vehicle warranty.
* for more information, refer to the provided copy of Saleen Technical Service Bulletin STB06-005a
Rotor Clash on Twin-Screw Supercharger
The Saleen Series IV and Series VI superchargers are extremely efficient twin-screw style superchargers. They are chosen for their excellent power delivery characteristics, and for their ability to keep air temperature cool and maintain high boost under harsh operating conditions.
The twin-screw style superchargers feature tightly bound rotors. As a result of the tight tolerances, the rotors are relatively loose when cold and when the engine is running at idle. This causes a whirring noise to emanate from the core of the supercharger which is known as “rotor clash.”
If a twin-screw supercharger is noisy when cold and running at idle speeds, but the noise subsides as the car (and the supercharger) warms up, and as engine speeds climb into normal driving speeds, the supercharger may be considered to be operating properly.
All superchargers are carefully examined after being assembled, and are pressure tested before shipment. The Series VI unit is also subjected to a special test stand where it is run at high velocity; the noise level from the supercharger is measured and compared to a pre-determined standard to ensure that all moving parts are properly installed and working as designed.
An easy field test for a supercharged vehicle is to compare it to an equivalent Saleen supercharged vehicle.
If you have any questions, please feel free to contact us at 800-888-8945.
Hawgman
THE fucking bad guy
What file format is it in? I probably have software to convert it to PDF if you like
And it's a damn good thing because it is a BITCH to change the oil in one of these.
A ROM error in the PCM after programming? Wonder what that's all about? Makes me glad I bypassed ever having a Saleen tune.
I'm sorry.. that part just makes me giggle. I wonder what brain trust at Saleen came up with that diagnostic idea.
Hey man, not heckling you for posting the info, just heclking the info.
Thanks for posting it up. I am sure many will find it useful.
tmcolegr
Central, FL
PM me with your email address and I will forward the document to you. Maybe you can convert it into something more user friendly.
Hawgman
THE fucking bad guy
done
major_harley
Elkridge, MD
Installation manual instructions regarding intercooler:
Page 53, item 117. Fill the intercooler recovery tank
with an 80/20 water/anti-freeze mix,​
to 1” from the top.
Maintenance manual states 50/50???
Which one is right?
Hawgman
THE fucking bad guy
Damn good point. Maybe that's one of those gray areas. Kind of like the three differnt versions of the install manual, each having a different version of the vaccuum line routing.
Maybe it is just a misprint since items 110 and 114 reference a 50/50 mix for the engine cooling system
Hawgman
THE fucking bad guy
Hummm... was nosing around on Saleen's web site and noticed something in the upgrade package descriptions.
".......and SCT Xcalibrator II tune by JDM Engineering."
Hawgman
THE fucking bad guy
Todd, you got mail. Figure since it is your document I would let you decide if you wanted to post it up or not.
tmcolegr
Central, FL
Hawgman thanks a ton!! Doc was able to convert the entire manual into a PDF. Go Doc!!
