Hey all,
TUNERS HELP!!!
I installed a Roush R2300 supercharger kit on my 05 Mustang GT in early August.
After the install I took it to my local Mustang specialty shop to have it dyno-tuned.
The tune went well, and the car drives fine. WOW!
However.... ever since having it tuned the car's speedometer went off by about 5MPH at 60MPH.
This was easy to compensate for by changing the revs per mile.
But I have never had to do this before.
What is worse is that the computer thinks it is getting far better gas mileage than it really is, and it thinks its using far less gas than it really is.
Example: Car displays 22.2MPG.... actual MPG is 12.6.
Example: Car displays 8.5 gallons used... actual was 12.4 gallons from fill up to fill up.
Fuel gauge showed slightly above 1/4 tank needed 12.4 gallons to fill.
So the fuel gauge level seems to be off. Showing slightly more fuel in the tank than there really is.
The tune shop double checked that the fuel injector size and the axle ratio were correct in the tune file.
I should mention that the tuner had to add a Kenne Bell Boost a Pump since my pump could not keep up at WOT. I spoke with the folks at Kenne Bell.... they tell me this is likely a tune issue.
The live-link showed me that the fuel pump voltage never went over 10VDC, so the boost a pump doesnt even seem to be kicking in.
I spoke with the folks at Roush... they tell me this is likely a tune issue.
I have reloaded the tune, reset the KAM, and reset the entire ECU many times.
And I have driven well over 2000 miles. No change.
Anyone want to make a guess on what could be wrong?
Thanks.
TUNERS HELP!!!
Thanks.
