Hey guys, having a strange problem. So, I swapped out my suspension for about a month or so, then after a few track days, switched back to stock. I didn't have this issue before the swap, so it's interesting to me that's its just now occurring. I'm having a very loud, noticeable creak from the front end when I turn the wheel at very low speeds or full stops. it seems to get progressively louder as the wheel is turned further off center. The spring isolators are installed, and I replaced the tie rod ends thinking that could be the problem, but it didn't fix it. Any thoughts on what this could be? Is it possible that I maybe installed the front springs upside down (is there even a designated direction they should be facing)? when I installed the strut mounts, I installed them with the arrow facing the outside of the car... was that incorrect maybe?
