1,030 rwhp Procharged GT350
Discussion in '2015+ S550 Mustang Chit Chat' started by Gabe, Jul 27, 2017.
  1. Gabe
    Gabe Whippled Coyote
    6,210
    37
    Aug 7, 2011
    NH
  2. tjm73
    tjm73 of Omicron Persei 8
    7,951
    32
    Jun 9, 2010
    Rush, NY
    This is just getting absurd.
    Making that kind of power and it will still be 100% emissions compliant is crazy! Power is nothing more than dialing up how much you want now.
  3. fast Ed
    fast Ed forum member
    307
    Nov 2, 2014
    Caledon, Ontario CANADA!
    Sounds like a time bomb to me!!
  4. TGR96
    TGR96 el blanco nino
    10,300
    8
    Feb 15, 2011
    Huntsville, AL
    ^^^ +1!
  5. redfirepearlgt
    redfirepearlgt forum member
    1,864
    15
    Mar 19, 2011
    Even with the 5.2 displacement, flat plane crank and Forged stock internals, that is a far stretch with regard to reliability IMHO. Impressive no less.
    Is there any indication if the setup is on E-85? I would have to assume its either being fed cord or race fuel. I don't see 93 octane making that kind of power under those conditions. Locally the highest output I have seen personally from 93 is 750ish RWHP on a 13 GT500 5.8L setup.
  6. Gabe
    6,210
    37
    Aug 7, 2011
    NH
    It's on E85, tuned by Rob Shoemaker
  7. tjm73
    7,951
    32
    Jun 9, 2010
    Rush, NY
    E-85 is disappearing in my next of the woods. I wouldn't tune or set up for it where I live. I think we are down to 3-4 stations now.
    Non-ethanol 89 and 91 are one the rise however. More and more stations have it.
  8. redfirepearlgt
    1,864
    15
    Mar 19, 2011
    ^^^ Main reason I never went to it.....Availablilty.
  9. palanza7
    palanza7 forum member
    610
    Apr 6, 2015
    well when you've got like what 80,000 to blow why not lmao
  10. sdleo29
    sdleo29 forum member
    503
    Apr 15, 2014
    That size pro charger sound like a jet engine under the hood... sick power, but I can't take the sound... much rather have a big ass PD blower and maybe a nitrous shot
  11. JeremyH
    JeremyH 3V Fuel Guru
    20,528
    39
    Jan 10, 2009
    It's all about the combo efficiency for as far as your fuels octane rating will take you, iat's, compression etc. We got 1017rwhp out of a twin turbo 9.3:1 comp 5.3L 3v at 21psi on 93 pump 15 degrees of timing. Iat's were within 5-10 degrees of ambient of the setup.
    I have 93 and e85 tunes for that reason, although if you live near any big military installations they always seem to have e85 pumps around due to them ordering a ton of flex fuel vehicles. It still depends on where you live, but if you look at the industry every year production of ethanol fuel has been significantly increasing in the US.
  12. palanza7
    610
    Apr 6, 2015
    just insane power out of a stock engine, on the gt350 chassis no less. my god
  13. Pentalab
    Pentalab forum member
    2,054
    35
    Mar 5, 2013
    How do you manage to get IAT's within 5-10 degrees of ambient with 21 psi + 93 fuel ? What's the trick ? How hot is the discharge temp from each turbo, before they combine, and are routed to the air to air HE ?
  14. redfirepearlgt
    1,864
    15
    Mar 19, 2011
    Man that is super impressive to see 1000+ on 93 pump gas. And 15 degrees WOT timing advance on 21 PSI? That is very nice. What type of heat removal system are you using to maintain your IAT's that efficiently and that tight with? No meth or water injection to help with that?
  15. JeremyH
    20,528
    39
    Jan 10, 2009
    Kit design, turbo size (highest efficiency island on the compressor map), placement(outside the engine bay), water cooling, pipe size/routing, and yes a large a2a intercooler, larger than any standard 3v kit I have seen have. And lower compression for less static cylinder pressure/heat and more area for cylinder fill, was a recipe for serious power efficiently.
    Correct no meth, a2a intercooler. Is easy to make a lot more power without needing more octane when you drop compression and keep iat's low.
  16. redfirepearlgt
    1,864
    15
    Mar 19, 2011
    ^^^^ very well thought out and designed Jeremy. The method and planning you used to get there is as impressive as the number.
Share This Page
