2005 GT suspension upgrade...
tyndallcbr
Hello,
I have a complete 2011 GT TrackPack suspension (struts/shocks/springs). Is is possible to bolt this suspension into a 2005 GT?
Thanks,
Sean
BULLITT1
SPRING, TX
My advice to you would be to take measurements and compare the track pack suspension parts to the oem parts. You might only be able to install certain parts. Some sites such as AmericanMuscle or LMR list some
parts are compatible from the 10-14's to s197.
hope this helps.
01yellerCobra
San Diego, CA
The only things I know about personally are that the strut mounts are different. They'll bolt to the 05-14, but you need the correct struts for the generation. Like 06 struts need the 05-10 mounts.
And then the rear upper control arm is longer on the 11-14 and require the matching body side mount.
GriffX
I changed the sway bars with 2014 take off parts. One of the best modifications I did so far. The 2011 upper control arm is waiting for install, it should modify the instant roll center and anti squat.
Beckett88
Washington
I’m new to the mustangs .... so hopefully I’m not asking a dumb question but what is the difference between the gt500 strut mounts and the standard Gt mounts and can you reverse the standard mounts also for more positive camber. Thanks
