46addict
13726548
From my limited understanding, low o2 voltage points to a lean mixture which sounds right if the sensor is behind a functioning cat. The cat is supposed to burn off emissions with heat so it would make sense for the downstream readings to be leaner. The spiking should still occur, just not as often as the upstream o2s.
