slvr08gt
Got my car dynoed a couple days ago. Just looking for some opinions on the numbers it put down and the hp/torque curves. The A/F reading at the bottom was tail piped so the actual reading is a bit richer than what the readings show. I do believe that there is some power left in the tune because my aeroforce wideband is reads 11.00-11.15 during WOT which is a pretty fat in my opinion. Tune is currently set at 15 degrees timing also. I was honestly expecting a little higher numbers but as long as its running safely, im fine with that.
Dyno Vid:
http://www.youtube.com/watch?v=_6Sn8...2T_YFuEn1cFhkD
Dyno Graph: Numbers are in SAE and it was a 5th gear pull.
Current mods are in sig below. TIA!
-Nick
Dyno Vid:
-Nick
