6R80 Help
Discussion in '2015+ S550 Mustang 5.0L Tech' started by newstang1, Oct 29, 2017.
  1. newstang1
    newstang1 Junior Member
    Oct 29, 2017
    Hi all, not sure if im posting in the correct area but hope someone knows about 6R80 transmissions.
    I put a Coyote with a 6R80 in a 609 mustang,
    I have the doner transmission shifter but am using a Winters Sidewinder instead.
    I noticed the stock shifter only has PRND2, but the trans has 6 positions after the P.
    does anyone know what these are for?
    in other words, my sidewinder has all those positions available, but i want to make sure i wont damage anything going into the positions that were not used.
    thx
    pics attached
  2. sportinawoody
    sportinawoody [email protected]#$%^&*(
    2,209
    Aug 10, 2008
    Piedmont area , N.C.
    the detents in the sidewinder are more than likely going to be spaced differently rendering that shifter useless.
  3. tjm73
    tjm73 of Omicron Persei 8
    7,845
    13
    Jun 9, 2010
    Rush, NY
    Not if he makes a custom linkage to account for the geometry difference. My brother made a 4R70W linkage to work with a factory C4 shifter with a customized linkage arm at the transmission. The C4 and 4R70W detents aren't the same.
  4. RocketcarX
    RocketcarX 95% of my weight is fuel
    1,660
    13
    Jul 19, 2011
    Burton Texas
    The C4 and 4R70W detents are exactly the same, I think they refer to it as "2 inch spacing". The reason they seem different is variance in arm length and bracket mounting style required to use the same shifter on different transmission.
    That's why all the adapter kits for the 4R70W swap are made to use C4/C6 shifters.
    Not to take away from your response, you're right, making linkage is all it takes.
  5. tjm73
    7,845
    13
    Jun 9, 2010
    Rush, NY
    He used a green dot shifter and it didn't match up. So he changed the shift arm length on the trans
  6. tjm73
    7,845
    13
    Jun 9, 2010
    Rush, NY
  7. RocketcarX
    1,660
    13
    Jul 19, 2011
    Burton Texas
    What is the green dot arm from? My trans started life as a 5.4 truck trans, so the arm is different than the Mustang arm. I'll def have to make something.
  8. tjm73
    7,845
    13
    Jun 9, 2010
    Rush, NY
    He modified the 4R shifter arm that came on the transmission to work with the shifter. I was wrong about the shifter. It was from a Foxbody. But the detent spacing wasn't the same.
Share This Page
