I do have the Ford Racing Radiator Fan, but you as well as a couple others have made me aware of the backpressure thing and I have to get some shrouding back around the radiator.
This all comes back to my original start of this thread not trusting these vendors telling you this will bolt right in and improve things greatly.
Yeah, it will... 'bolt right in'... with the caveat that you have to do a ton of supporting mods / chopping / hacking /etc...
to make the damned thing... 'bolt right in'.
One thing I can't do right now, and that's measure eng oil temps...nor eng oil pressure. I highly suspect for road course duty, that the eng oil temps will exceed 300 deg F. Folks with the 11+ cars that run em on a road course
(and use a manual tranny) typ report eng oil temps > 300 F. Eng oil coolers are not cheap, however they come in a wide variety of widths, depths and heights.. they also have to handle the pressure..as well as high temps. 100% synthetic oil is good for > 300 F..barely. Semi synthetic + plane dino oil is done by 250 F. For a few 15-20 min track sessions, 100% synthetic should be ok, it can always be changed more often.
You might want to focus on how a custom shrouding job can be done, if at all possible, to increase your total airflow.
Depending on how much room you have in there, one or more of the B+M auto tranny coolers would do the trick. The mishimoto tranny cooler you currently have I suspect is gonna be fairly thick, including the fan. One of the bigger B+M units, like way bigger than what I use, in height and width.... and 1.5" deep would work. Dunno how many BTU the oem ford tranny cooler is rated at, but assume at least 10,000, based on it's surface area. You need another 10-13 K btu on top of that. The B+M model 70266 is 11 x 8 x 1.5 and is rated at 20,500 BTU. This would work.
http://www.bmracing.com/products/70...tings-plate-type-black/?mk=&yr=&md=&smd=&eng=
The B+ M model 70274 is 11 x 11 x 1.5 and is rated at 29,200 BTU. Now this definitely would solve your tranny cooling issues hands down, bar none.
Flat out, blower on, you shouldn't be seeing tranny temps > 175-180 F.... IF you use the appropriate cooler. 20-30 K BTU is the window. Now whether that comes from one big cooler, or 2 x smaller ones is a moot point. In your application, one of the 2 x larger ones I listed above would do the job..... provided you have the room. Two of the slim line 3/4" thick ones, will also do the trick. 13,300 BTU..EACH, 26,600 BTU total.
http://www.bmracing.com/products/70...13000-btu-rating-black/?mk=&yr=&md=&smd=&eng= But these are 11 x 8.5" tall x 3/4". 2 x stacked = 17". So you have some options to play with. Their bar + plate designs are far more efficient than the older tube + fin config. You don't need a tranny cooler with a fan, what you need is a bigger surface area, or more specific, total core volume. But the caveat is.. it's gotta fit. At speed, you will have a ton of air flowing through it, no fan equipped cooler required.
