AC/Heated Seats panel not Working
Glenn Ford
McDonough, GA
AC/Heated Seats Control Panel not Working
I have had an ongoing problem with the Radio/HVAC control panel in my 2012 Mustang GT. This is the panel containing all of the radio/CD/Hvac and heated seats controls - see picture below. The AC and heated seats do not work (no orange lights). The Radio/CD works fine. Relays and fuses are good. I replaced the entire control panel 7 months with a used panel and everything worked until this week and the AC went out again. I have posted this issue on several Mustang sites and no one can help me. Hopefully someone here can help me resolve this issue.
Thanks very much.
Glenn
th
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
If I remember properly, that entire panel only has a single plug with like 4 or 5 wires, right?
Glenn Ford
McDonough, GA
A small diameter 4 wire twisted cord into a small 4 pin plug. This cord controls all Radio/CD/AC/defroster/heated seat controls.
The two bottom rows of controls do not work - AC and heated seats.
Glenn Ford
McDonough, GA
No engine check light on. Do the B codes register without the engine check light coming on?
These B codes I was reading are unreal - they monitor EVERYTHING. Will a normal OBDII reader read these B codes?
Heat and defroster work, but no AC or "on" orange lights in the control panel.
rjyote
B (body) codes don't turn on the check engine light (MIL). P (powertrain) codes do that. Cheap OBD scanners won't read B codes, only P codes. You will need something like an IDS to read B, C (chassis), and U (network) codes.
Sky Render
NW of Baltimore, MD
I think the module that controls your HVAC might have an issue, not the actual button/display panel.
