datmbn
The problem is that the alternator at some uneven intervals charges over 16 volts for a second and then returns to the correct value again.
I discovered the problem because my androidstereo restarted seemingly unmotivated.
I then connected a voltmeter so I could monitor the system, and you see that it behaves completely as expected (maybe a tenth of high voltage)
to suddenly give 16+ volts in a second maybe once a week or two times in an hour.
Does anyone know what can cause this.
regards Mats
regards Mats
