Brick
So here's my situation... I have a set of new OEM plastic tensioners that were installed, primed, and then had to be compressed by hand (I used the chain guide to slowly push it back in while still installed) and removed when I pulled the head to retrieve a bolt that dropped down in the combustion chamber.
- Can OEM plastic tensioners be reused if they are removed in this manner, or should they be considered a one time use item when installed and primed?
