QWIKFIX
I have a 50 amp GFCI for my hot tub...secondary to my main breaker panel in my garage. After 15 years of use I started tripping the breaker. I did some checking and found that my breaker overheated and actually partially melted at one of the inputs. One wire going into the breaker was a 6 gage wire that was too big for the breaker and the electrican cut down the wires to make it fit...not too many wires strands were left. That wire was also burnt a bit on the insulation. So I bought a new breaker and cut back the burnt wire. I then bought a wire reducer to put on the 6 gage wire then on the other end connected a short section of 8 gage to go to the actual breaker. I used heat shrink wrap to cover the reducer.Now I'm wondering if this breaks any "codes" or if this is kosher. Granted this may not be the actual problem...but i needed a new breaker to start with. Here a shot of it before the shrink wrap. (the bad wire was the orig black wire going to the left input) Thanks for any info
